And now for something completely different, sorry i lie like a cheap watch!!
BattleshipBob
Cardiff
With the tiny Rutscher nearly ready i thought one last build before i tackle the shelf queens and que for painting and weathering, there's a lot :anguished:
Takom new 1:35 StuG Ausf G, early production
I was not going to get his kit BUT it’s a StuG so the force was strong! (still waiting for the new sprues for the Pz 111 M kit by the way) plus paid £28.00!
There’s a good few discussions about this kit on the web so thought I would include my half a pennies worth!
This is aimed at the venerable Tamiya early StuG G, which although inaccurate is a pleasure to build. This kit has no interior and lacks the detail of Dragons later StuG kits, plus the new NEO kits, but a great deal cheaper.
Being picky, in my eyes it’s NOT an early Ausf G, the first G’s were built in December 1942 by Alkett and on Ausf F-8 hulls. They still had the driver’s side vision slit.
Out of the box it’s a StuG from the Miag factory, they started StuG G production in Feb 43.
Its Miag build as the position of the fire extinguisher on the rear left hand fender has its head is pointing away from the body. Alkett fire extinguishers pointed inwards, however this changed 09/44 when the extinguisher was moved inline and closer to the body
It’s far more accurate than the Tamiya Kit and its build date is March 1943
Correct bits for a Miag StuG March 1943 build
Interlocked welds on the superstructure
Correct welds on the engine deck
Smoke canisters: Feb – May 1943
30mm bolted on additional armour covering the driver’s visor: March 1943 onwards
Roof has the correct design and screw fixings: Feb to May 1943
Fire extinguishers position
Fender supports
Lacks the side skirt brackets, April 43
However you could build it as a later G by adding
The brackets for the side skirts which were added in April 43
You could add a towing pintle on to the fan drive belt adjuster cover on the lower rear hull as this was added in Feb 43 but it was not always fitted
Or you could build it as a early StuH, be aware all StuH were built at Alkett
The howitzer metal barrel is readily available
Move the fire extinguisher so the head points in towards the body
Alter the fender support brackets
Problems
Wrong rear convoy lamp, kit comes with the rectangular one ok for StuG G hybrids, built on ready made Pz 111 hulls.
Should have the tubular lamp: Feb 1943 onwards
Instructions say to mount the two towing S hooks on top of each other and then fitted to one fender. This is wrong; they should be mounted separately on the left and right fenders.
And now for the kit, the most of the sprues are from the Pz 111 M, so interested to see after a fair bit of complaints about the fit and moulding if Takom have done anything???
Its a StuG, whats not to luv :cool::tongue-out3::thumb2:
Normal service has been resumed! :smiling2: ;) :thumb2: :cool:
Looks a great kit. Looking forward to seeing how it turns out. Good luck mate
Thanks Steve, enjoying checking kits against my knowledge. Never thought i would become a revit counter ;)
Hope you are well, watching your YT stuff:thumb2::thumb2::thumb2::thumb2::thumb2:
Si not enough StuG, never be too greedy lol
Good to hear from you
Bob
Beats me how you guys manage to dig up all this information! Not just you Bob, there's lots of you out there with encyclopedic knowledge of a range of subjects. How come the manufacturers can't find it? I appreciate that sometimes they will make decisions based on other factors such as cost or mould difficulties, but things like the placing of a fire extinguisher shouldn't be a problem!
PS Edit: NO! I can't do it. It should be encyclopaedic! I feel better now.:smiling:
I am one old sad git:tongue-out: its a hobby for me, just read a lot. Being a truck tech then teaching it helps, use to reading about truck stuff to learn
I pick a photo then test my knowledge by trying to work out, ausf, month and year etc. Now time for tablets!
Takom just being lazy by using the same bits from the Pz 111 M. But as you say its not rocket science
COUNT ME IN AS WELL Bob MAY NOT KNOW MUCH about these stugs but i know they are a tank killer so thats a start
chris
Well done Chris, 10 out of 10, getting there ;)
Next is a 5 hr exam:flushed:
I'm not free but I'm very cheap!
PS I don't think Mr Humphries was cheap - just desperate!
PPS See? I AM that old!
Excellent lol
2 old gits ;);) even know his name, well done sir heard he was a x paratrooper! Honest:thumb2:
Bob
I'm in shock. This is actually a genuine Stug!! Never thought I'd see the day when you built one of these!!!
ATB
Excellent lol
Make that 3 sad old gits as i remember him an the show an the goregous miss bramms played by wendy richard
Morning Bob
Does it pass the wheel alignment test?
Or are they the same off centre ones you had before?
Another Stug, why not LOL
Have fun
Regards
Steve H
Bob,
I'm sure you'll make a real hash of this one !! :flushed: :smiling2::smiling5:
Mr Cuthbert would like to know if a "Stug" was ever developed using different chassis??
(He's currently stuck in the lift with Captain Peackock & Mrs Slocom ;)).
Clearing out the man cave - I came across some leftover sprue's from Dragon's 6226
Bergepanzer Tiger "P" and one of the pieces is definitely "Stug" shaped !! ;)
Paul.
:smiling2:
