Evening all.
I'm sure we've all been there when the shelves are full
The time comes when there is just no room left , even on the front . So the packing away into the loft was started.
The first to go was the.
Failure to get it through the hatch in to the prepared space.:cold-sweat: So took it back down stairs and stripped it down ! Kept all the figures, including some from Peter Day.These are now packed in bubble wrap for use again.
The armour and that truck are saved also for use in dio builds. The rest has gone in to the landfill bin, it's been on my mind for some time as to what I'm going to do with them all .Glad that it's done. I taken some photos to print off.
Next was the KV2 quite an early build, members from MM might well remember both of these. This went through the hatch and is going to be the families job to ditch it later .
Saved kits to reuse. Esp the StuG's :smiling::smiling::smiling:.
So that leaves a nice gap . Soon filled the top shelf.
The new dio will go on the left.
Finished this as well as found the cockpit.
Might now feel more like working at the bench .
John.
John.
