Eduard 1/48 Fokker D.VII
Dave Ward
After the Albatros D.III & the Fokker Dr.I, I'm going for the ultimate WWI fighter - the Fokker D.VII
I have a Roden boxing in my stash, but I have two Eduard versions:
I want to use both as German WWI aircraft, and with a bit of cross kitting, I can turn the MAG Red Star version into a 1918 fighter ( it has a different engine, different fuselage, different machine guns ). There are enough spare parts - especially the fuselage in the OAW version to do this - the only part that has to come from elsewhere is an exhaust - and that is an alternative from the Roden Model!
These are the weekend versions, no PE, masks etc. The D.VII has minimal rigging - just as well with the extensive decalling.
These D.VIIs had the lozenge covering on upper & lower wings ( and sometimes fuselage as well ). I probably won't be using the Eduard decals, as I have an after market decal sheet ( Print Scale ), which provides me with the additional lozenge sheets & some fancy artwork versions.............
I'll put up some sprue shots shortly
A box full of bits:
Fuselages - one spare, which will be used................
And decals - not Printscale, but Lifelike.
And lozenges, top, bottom & ribtapes - I may just have enough!
One of the problem will be deciding exactly when to apply the decals. I can see that the decal solutions will be taking a hit!
You must be seeing double with all these wings recently :smiling3:.
Another interesting subject to build. I have the Red star job in the stash so it will be good to see how this goes together....
Tim,
I have the Red Star version, because it was the cheapest Eduard Fokker D.VII - and still is! I didn't realise at the time you couldn't make a WWI version 'out of the box'. The surplus bits from the other Eduard Fokker has solved that!
I think I bought that kit cheap at a show for the same reason.....but until you posted this, I didn’t know it wouldn’t produce a WW1 version either.....
Tim,
the fuselages are different - the WWI is grey, the Red Star caramel ( just taped together to show differences )
This is to take a different engine, but the original engine is still included - which I've put together & detail painted. The Red Star version also has Vickers mg, but the original Spandau guns are on the sprue.
The differences only become apparent when you lay the sprues out next to each other............
A miserable rainy dull day here, so I cracked on:
The fuselage is just about ready to be closed. Some spare decals used for instruments & masking tape for seatbelts
Apart from really tiny parts - the seat frame being the worst all parts fitting well, but the instructions do need careful study
Fuselage closed - no need for clamps, just tape to hold it. No nasty noises!
The Fokker has very little painting, the nose is dark green & the tail surfaces are white ( with green decal stripes ). The rest of the airframe is essentially covered in decals. I just brush applied a gloss varnish coat, then made a start, by applying most of the pale undersides
I used Humbrol Decalfix - it's a bit fierce, but there is such a large area to cover, I reckon it's needed.
I'll let this dry overnight & then do the darker upper surfaces tomorrow.
Once these are applied, I'll seal all in with varnish, then comes the really tedious part - applying the rib tapes - each an individual decal.................
After drying overnight, I've added the upper surface decals
I'll really let this dry, and there are areas where a little more decal solution will be needed. Then an overall gloss varnish coat. I can add the fancy fuselage decals, whilst it is easily handled.
Lozenges look good Dave. That’s a job that would be very difficult prior to decals being available. One of the things I occasionally muse over...are the lozenges painted on the real aircraft, or were they stitched together from fabric pieces ?
You're a machine Dave and this is looking tops!!! The decals look really good too. Were they difficult to put onto such a large surface???
Maybe time for a new cutting matt me thinks...........
Allen
The lozenge fabric was printed, I believe - the strips were fitted either fore & aft or slightly angled on the wings. Rib tapes were then stitched along the lines of the ribs - must have been a really tedious job!
Allen,
The decals are pretty tough - applying them over a gloss finish does allow a little wiggle room. A decal solution is a must! I must admit that the mat is getting a little crusty - and this is one of the better ones!
Thanks for the heads up Dave. I have a WNW WWI Halberstadt CL II and the lozenge decals are huge. Definitely will spray a gloss coat on first when I build it.
And here I was thinking all that paint on the matt belonged on the models..............................
Allen
