And now for something completely different, sorry i lie like a cheap watch!!
Good to see you back sticking plastic, Chris is right where was the nut ?
ITS a bolt John not a nut lol an yes it is good to the the boyo doin something constucktive an Bob ive been studyin the pic an is it missin on the right over the drivers veiw vent ?
chris
Glasses folks lol. It was above the drivers visor, you can hopefully see were i have sanded it?
Never would have thought it Chris!! But yes i confess lol
ITS a bolt John not a nut lol an yes it is good to the the boyo doin something constucktive an Bob ive been studyin the pic an is it missin on the right over that vent ?
chris
Well spotted sir
Uncle Night Shift!!! Aka Martin Kovac. One of my favourites. Maybe not the absolute best but I like his self-deprecating style. I'm actually about a third of a way through that one.
Hi Andrew
Big fan of his, he does some very good how to vids as well
Shocking fit, how on earth that got out of the factory gates i'll never know:sad:
Hi Andrew
He is very good but what I really like is that he's not afraid to admit when he's got it wrong or is doing something for the first time. And as for the fit absolutely shocking.
So you are a rivet counter Bob oh my gawrd what next lol
chris
Hope this is clear picture of the two types of bolted on 30mm armour, protecting the driver. Top one is the Miag one with the missing centre bolt
YEA good pics Bob an yea i see the missing bolt an thats the one you are building ?
chris
Hi Chris, only used on StuGs built at Miag. March to May 1943
The main factory at Alkett only used the bottom one.
Completed the link and length tracks on one side but
Made to the number of track links on the plans but track seemed to long, picture shows tracks with one less, may be a tad too tight now! The built in sag on the top is not enough in my opinion?
Had to use bluetac to hold the return rollars as the attachment pin is too short, also had to glue the drive sprocket as again pin to short and theres a second locating pin as well. Not impressed folks!
Bob
Thanks Paul and Chris, might have to add the link i removed??
Hi Bob, it does look like it needs the extra link to fill the gap at the front on the bottom run, it depends on how slack or tight stug tracks should be. Maybe fit it in the bottom track run by the rearmost road wheel, to give it a bit of curve round the wheel looking at the picture.
Morning Graeme
I agree, but with the extra and its in the plans link it looks to loose. There is not enough moulded sag in the top run. Will have another look
Hi Steve, its held on by bluetac
Major problem is the lack of long enough rods on the drive sprocket and return rollars, had to glue the drive sprocket and it also has a small noddy on the back to locate it on the drive hub.
