Here are some updates for today...
I have stuck on the fuel caps and the circular bolted access points to the new positions. Notice that I have reversed the latch on the right fuel cap for right handed gripping.
The rear deck hatch has been corrected with sheet styrene. I shaved off the hinges and re-used them. Also I made the grab handle from copper wire, positioned a latch handle to the right and added three bolts at the bottom. I also replaced the bolts on either side of the hatch to match.
I have measured and cut screen that I will be using to replace the incorrect mesh. The frame work will be made out of foil from a Tamiya putty tube that I saved.
Hope I get to do more tomorrow.
