It is very much 'horses for courses' and it is not just about a single glue/cement but different ones for different jobs. I use the following:
For well over 90% of plastic to plastic my preference is Mr Cement S. It is an extra thin type such as Tamiya Extra Thin but, in my experience, better than the Tamiya. It is applied to a 'dry' join so capillary action draws it into the join and meld the plastic together. It grips very fast. Another type of extra thin that I find excellent (using at the moment) is Ammo Mig's. This type of cement is ideal because it means that you can precisely position parts before applying cement meaning a cleaner joint and no risk of smudging, just dont use too much. With large pieces I use pieces of masking tape or clamps to hold the parts together in the right position and then apply small amounts of cement between the tape/clamps making sure that you keep the cement well away from these. After a minute or two I remove the tape/clamps and then run a brush of the cement along the join. It evaporates from the surface without damaging it.
Sometime you do need a slower drying cement, it is for those odd situations when you cannot apply cement to a join and need to apply it to a mating surface instead. Often this is for small parts that you are positioning in odd places. For this I use Mr Cement DeLux but another good one is the Mig Ammo slow drying cement.
For attaching clear parts and avoid fogging it is best to use a white glue such as Gator Grip (my preference). This is also useful for photo-etch flat panels. There are sutuations when I use Mr Cement S for transparencies, when there is a good 'frame' that will be painted but overall it is best to use white glue for this. Micro Krystal Klear is also good for transparencies.
For attaching
resin and some p.e. then c.a. glues are useful. I use three types, thin, medium and thick. Each type has it uses.
There are two other types of glue that more rarely has uses. Two part epoxy and the new types that cure with a UV light. I have these but rarely use them but they are good to have in your armoury.
I would recommend using
https://www.scalemodelshop.co.uk/
to source your glues/cements and a lot more. It is run by John who owns this site and he provides a first class service.
