Not much to show again today, but then compared to some of the cracking scratch work this GB is producing, there never will be lol :smiling5: But since it's a group build, I'll keep bombarding you with build pictures :smiling3:
Upper and lower halves were married together, then I started adding the plethora of brackets and grab rails, the screen visor and snorkel
Tow poles and aerials have been cleaned up and put together. They should be fitted by now but they'll just get in the way, and aren't body colour anyway, so I'll paint them separately
The autocannon & MG needed a lot of clean up before assembly, and I took the time to drill out the barrels and muzzle break, following the moulded dimples the kit would have you accept.
And test fitted on the turret. The cannon uses a large keyed slot, and the MG a poly cap, so they'll be easy to fit after paint. The turret still needs the smoke launchers and lifting eyes fitting, but I've left them off until I've finished filling the seams & joints.
