In the spring of 1944, there were some calls in the United States Army, both in the USA and in Britain, to arm the Sherman with a 90 mm gun in order to take on the heavily armoured German tanks that were expected following the Normandy landings. The basic idea was to put the turret from the T25 or T26 designs, which were being developed for use in 1945, onto the M4A3 hull (plus to re-arrange internal stowage in the hull for the 90 mm ammunition, of course). Nothing came of this for a variety of reasons, other than an experiment using an M4, rather than M4A3, hull later that year:
Had it actually been put into production, the tank would have used an M4A3 hull, and be equipped with horizontal volute spring suspension (HVSS) rather than the vertical (VVSS) in the photo above, because both of those were the favoured variant in the US Army by late 1944. It would likely have been available by early 1945, so could have seen action in Germany instead of, or even alongside, the T26E3 (later M26) Pershing in the last few months of the war in Europe.
For a full history of this subject, including why it was not proceeded with, the Chieftain has a good video:
Now, I recently bought the following kit second-hand:
This is an M4A3 (76) HVSS in post-war configuration, as it was used by the Japanese Ground Self-Defence Forces. I never intended to build it as such, but rather, to convert it into what an M4A3 (90) tank may have looked like in operational use. And what better period for that kind of model than Operation Coronet, the second planned invasion of Japan in 1946? (The Allies intended to invade Kyushu in November 1945 in Operation Olympic, followed by Operation Coronet in central Honshu in early 1946 in order to capture Tokyo and hopefully end the war. Wikipedia has more on these invasions.)
Let’s start with what you get in the kit:
View attachment 412140View attachment 412141View attachment 412142View attachment 412143View attachment 412144
Plus, of course, instructions, decals and poly caps. Again, the modularity of Asuka Sherman kits is apparent, and also that there is some duplication of parts because they started with an M4A3 HVSS and then added sprues for the post-war/Japanese parts. The tracks are interesting: there are four lengths in soft plastic, to which hard plastic track pads and guide horns have to be glued. I will probably replace them by these from AFV Club:
… assuming I won’t get too frustrated by their overly loose fit, anyway
The majority of the turret parts of the kit are superfluous to requirements, as I will of course replace them by most of the following bits:
This is the complete (minus cupola) turret and a few other assorted parts of a Tamiya T26E3 kit (I just noticed there is an M60 stowage bin lid in there too by mistake, probably because it was moulded in the same colour plastic), which I have left over because I converted one of those a loooong time ago into the T26E4 that was actually deployed to Europe in 1945:
