I will say, I havent primed any of my gaming minis with airbrush, theose were all rattle can testors black enamel primed and then hand painted. But since Ive largely gone to 1/72 aircraft modelling I've exclusively used an Iwata Neo cheap airbrusb and a harbor freight compressor with Vallejo products and I've never had a durability issue with my primer, I shoot the Vallejo air Black primer neat at like 10-15psi depending on how its coming out, then I shoot white/grey for mottle coat like 30 minutes later, then like 15 minutes after that I start my thinned layers of the main coat to build up over the mottling. Granted I dont handle my planes often like you would gaming models, but I've only had a patch of paint and primer come up like once, on my first Mig29 I was trying to do semi-soft edge camo using bluetac, and left it on too long so it pulled up some of my paint, but tamiya masking tape has never done it, etc.
I dont know if I just have lower standards than normal or what, but I see people have trouble with Vallejo a lot, and my only real complaint is build up on the needle, which is fixed handily by a few drops of flow improver.
