I was, and had started, to build this completely OOB as a nostalgic piece since it's the same subject I built as my first model.
It turns out that, according to scalemates, this is an evolution of the Italeri AH-64A that I built back in 1995. Back then I preferred the 'A' thanks to the Nicholas Cage / Tommy Lee Jones movie and the fact it didn't have the hideous radar dome on it. Having since learned what this dome allows the Apache to do, I've forgiven the ugliness!
Obligatory box and sprues.
The final sprue appears to include all the updates for the 'D'.
Decals:
Some hand drawn instruction addendums:
A handy version scheme addendum:
The version to be built:
...and the mad Japanese scheme, just for fun.
As usual, I started work on the cockpit and naturally started at the gunners forward position. I pulled up some 'D' mark references and was horrified straight away.
It was clear from the instructions that Italeri really did just take the 'A' and made some cosmetic changes.
See the instructions:
Compare to the real thing:
First, it's not flat. Second, the targetting console is not the same at all. So I ummed and ah'd and decided that I would, for once, attempt some scratching to see if I could improve it. I couldn't make it worse....
I cleaned off the existing buttons and gauges and set about trying to make them up from plasticard, trying to build in an approximation of the angles of the screens and the general console array. I also butchered the targetting console to get something close. I plan on chopping up the kit decals to apply to this later.
I will need to scratch the hood I think aswell because the kit part projects way too far in to the cockpit and is totally the wrong shape and I don't think I can do this adequately without having the instrument panel in place. So the plan is to prime the entire interior which will need to include the rotor housing and seal it all up. There's plenty of room I think without the canopy fitted to get it all done.
I am well outside of my comfort zone here and am mainly posting for your entertainment / feedback / tips, so all are welcomed and encouraged.
Thanks!
:hungry: :tongue-out3:
Decals:
Thanks!
