HMS DREADNOUGHT 1906
Cheers Carl, appreciated
Will start KGV in the near future. Bought a wooden deck so all new too me as well. Trying to get PE set but hard to find unless you want to pay a lot!
I find a lot of the pe is just too small or delicate to use. I think the biggest improvement with pe is the railings which you can buy cheaper in 1:350 to most ships.
Got railings which inc the cranes, agree with small pesky parts, do my head in lol
Nice progress Carl.
A good while ago, my one attempt at P.E. railings ended up in the bin as I could never, no matter what I tried, get the railings running straight and true. They looked awful and just not good enough.
Nice progress Carl.
The key is not to look too
Closely and definitely no Macro shots..
Looks great...nice complex array.
Yes, it’s not gone too bad. I just have to watch my gorilla like arms from breaking other parts whilst doing it. Plenty more rigging to do mind and then a bunch of repetitive deck bits to finish and then place main guns. I’m on the home run now.
Does anyone know what the measurement of a chain link in mm’s would be for 1:350 scale ships. I have several chains but can’t decide which looks the correct scale.
I reckon about 1.5 to 2mm should be about right. Most warships use studded chain
It prevents kinking & fouling & adds weight - it's a lot more expensive than normal chain!
Thanks Dave, I have a few chains in my box which vary slightly in size so I’ll use the closest match and try to blacken it slightly with the MIG etch burnishing fluid.
I’ve decided to fit the many coal grates which there are roughly 58 in total over the deck. Because I fitted the wood deck that additional thickness meant these sank a little too deep into the deck holes. As luck would have it the wood deck also come with its own set of etched coal grates so I basically fitted the original 58 first as a packer and then fitted the 58 more to bring the grates to the correct level, give or take. So a tedious task was twice as tedious.
All part of the fun of shop building.
Some of them will need some grey paint touching up.
