HMS DREADNOUGHT 1906
IKB eh! Victorian self assurance at its best. When he designed the GWR main line from Bristol to London he arranged it so that the sun shines through box tunnel on his birthday!
Great work Carl, makes me wonder what i have let myself in for lol
I think the fact that I have only done short sessions when I can fit around work has made it easier going in that some of the more tedious task as mentioned are spread out. To be fair, those coal grates are not going to be on many ships so this is probably an exception. I guess the rigging is quite taxing but again I’ve just done little bits at a time and it soon takes shape.
live looked at HMS Hood and visually it looks easier to build compared to HMS Dreadnought but only time will tell.
Either way, I need some more relaxing build next so will most likely Build the P-61 Black Widow.
Thus giving rise to the expression "That Isambard, the sun shines out of his boxhole". Something like that anyway.
Carl,
HMS Hood was oil fired - just connect up a few pipes & there you go! Only warships really went through the horrors of coaling - their armour plating meant that you couldn't have large convenient holes in the side to get the coal through! Merchant ships didn't have that problem & passenger ships had purpose built chutes, so they could load coal faster & cleaner! - Which is why the older coal fired ships had such large crews!.
As an aside, the limiting factor of speed in the early destroyers wasn't the engines, or the hull form - it was the strength & stamina of the stokers! You only had a limited number of stokers - If you had more stokers, the ship had to be bigger, and the coal bunkers became more widespread. So as coal was used up, the trimmers had more difficulty in supplying coal to the stokers. Running at full speed would quickly exhaust the stokers ( and I'm talking about hours, not days! ). One of the main reasons that destroyers were oil fired pretty quickly
Carl,
Yep, who’d want that job now a days..
As a follow up..................
The destroyers, before being accepted by the Navy had to run speed trials. There were cash bonuses for every .25 knot above the contract speed, and penalties & even rejection below .
The builders used to employ specially trained teams of stokers, and literally hand picked the optimum size chunks of best Welsh steam coal, to give them the best chance of gaining bonuses!
I tried to burnish my chains but to be honest it just didn’t seem black enough so I’m the end I resulted to spray painting them in MRP black. Because the MRP paint is so thin it doesn’t seem to clog the chains.
The MRP is smelly paint to spray but it really is amazing stuff to use. Just work well every time I use the stuff.
Need to buy some more soon I think.
Lovely Carl
Learning a lot for my ship attempts!
I’m sure with your experience your be fine Bob.
That said it’s amazing how you just keep
Learning every model you make. Always some challenges to overcome. Guess that’s what keeps me interested.
