Hi all,
I've recently got a cheap compressor and airbrush to start with (an AS18-2 compressor like this one in John's shop). I'll be mainly doing Military Vehicles.
After doing some research, I found multiple answers to the same question. Rather then opening multiple threads, I hope you don't mind me asking some in here:
1) is is ok to thin Vallejo Primer with the Tamiya acrylic thinner (XF-20a)? Or would I need to use the Vallejo Airbrush thinner? Also, I read the right ratio should be 50:50. Is this right?
2) Same question as above but for Vallejo Matt Varnish. Is it ok to thin it with the XF-20a?
3) For the actual painting of my models, I'll be using Tamiya's acrylic paint (XF) hence having the thinner of the same brand for the painting part, is the 3:1 (thinner
aint) the best ratio?
4) If I get well with AB, I plan to upgrade to the Harder & Steenbeck Ultra Two in One [v2.0] which comes with 2 needles 0.2 and 0.4mm. Is this a good one for a novice?
Thank you for any help!!
