In my experience North Americans don’t seem to use A4 as a paper standard either. Many years back we were carrying out contract pharmaceutical manufacturer for a Canadian company who (reasonably) wanted copies of all documentation, including SOPs etc. Trouble is, when we sent the electronic copies they wouldn’t format properly on their standard paper, which was smaller. They wanted us to reformat all the docs onto the smaller standard, which was a huge amount of reworking. When the meeting started getting a little “precious “ I suggested a work around which generated a bit of a sense of humour failure . I said “why don’t we scan some blank A4, Fax it over, and then you can photocopy as much as you want for use in printing”……..Strange that metric system was brought up. As a design engineer, I worked for a British Company, we were totally metric, and I was tasked with designing a gas engine conversion - we made diesel engines, so I had to do different pistons etc etc. As a diesel, there were no spark plugs, or electric ignition system, so I had to work up a system from scratch. I value engineered everything, even going for over specced bearings, as they were the cheapest I could find. It worked nicely, looked elegant & was within budget. UNTIL our US subsidiary started bleating about metric bearings! What was the cheapest bearing in Europe was one of the most expensive in the US, and they had to have a certain percentage of American produced parts to qualify as 'US Made' . The US was geared up to large diesels, and I had to redo the design to use clunky parts designed for engines 3 times the size! All because the US is one of the 3 countries in the world that have not accepted the metric system! ( The other two are Liberia & Myanmar! ). The design looked terrible, patched together with oversized parts - I always kept quiet when anyone asked who has designed the monstrosity! Consolation was that it worked pretty well!
