Update.
Sad day down a t'mill.... Oss saddler done run off wit' button maid.....
So there I was all full of myself - the tracks finally assembled and pinned onto my track painting board. I found an old tin of Humbrol Natural Steel for the end connectors and spryed it onto the pre primed tracks. Next came the Dark Rubber, which was brushed on..... and of course knocked off a couple of end connectors - and that should have been the warning sign. It appears the car primer has weakened the small amount of cement used on the end connectors - but no problem re-glue and carry on :rolling:
I decided to add the tracks first, get them settled and then do the weathering hip hop..... So off we went gently running the first end past the idler wheel and then all the end connectors started falling off :flushed:, they were everywhere, on the bench, on the floor, you just had to laugh:tears-of-joy:....
There was no way to recover, so it was a quick trip to the bin, and luckily I have another box of the same (Is he mad or what? the man's insane!!!!) So I am going to try a different approach, get SWMBO to assemble them and then I can blame her (Ouch!!!!)
Seriously, I have had a think and will try a different route, add the end bolt heads as per my earlier comment, but then cement the track pin to the end connector first to make sure there is glue where glue should be. Pictures to follow, in case anyone else is now sitting with a pile of scrap tracks and cursing my name.... Oh well Hippity hop.
On another subject, talking to an old friend from my BAe days at Hatfield in their model/detail department, who is also a mad modeller like us all. We came to the subject of tanks and what are you doing now? He informed me that where he now works they are developing a succesor to the Challenger/Megatron, but still based on the Challenger. It will be called Emperor, and will have a coating similar to the 'Barracuda' camouflage covering but with an electrical circuit running through it (called ENC1). When the circuit is activated it creats a blurred effect, not invisible, but reflects its surroundings ie trees, bushes. So it must be something like a mirror effect. He would not go into too many details for obvious reasons, but the joke/challenge was - now how do you replicate that in model form...
So there we go, now more of the tracks later as I said, a little set back, but if i was honest, I did see problems but not a complete disaster - more later.
Mike.
