Thanks Tim, do you thin it??I’ve used the Matt varnish. Behaves very like Tamiya varnish, but seems to have finer Matt particles. It sprays well and dries Matt and clear. I’d recommend it!
Sorry, only just seen this Bob. Yes, I thin it exactly as I do Tamiya stuff. Usually I do this by filling a new bottle to the bottom of the neck with MLT before I spray with it. This is about a fifty fifty dilution. I don’t use these paints for brush painting so making them “ready to spray” isn’t an issue for me. It may need slight dilution adjustment before it’s ready to go, but this gets me pretty close.Thanks Tim, do you thin it??
Bob
Not a problem TimSorry, only just seen this Bob. Yes, I thin it exactly as I do Tamiya stuff. Usually I do this by filling a new bottle to the bottom of the neck with MLT before I spray with it. This is about a fifty fifty dilution. I don’t use these paints for brush painting so making them “ready to spray” isn’t an issue for me. It may need slight dilution adjustment before it’s ready to go, but this gets me pretty close.
Excellent AndyI've used most of them Bob, they are my first choice.
From the super glossy gx100, their gx112 which apparently adds UV protection, and a few of the matt ones, with gx113 being my favourite.
As with Tim, I thin them with MLT. They are pretty thick in the bottle so you wouldn't want to try them neat! I've tried their rapid thinner with the matt, as recommended by Mr Color, but I find MLT sprays better as long as you don't want the ultimate in flat/matt finishes.
The gx 100 can be thinned right down for thin wet coats giving a great gloss. I go as much as 1 clear : 4 thinner, but I've seen other go as far as 1:6 for the final coats (using thicker coats first) on cars etc. to get it to lay like glass.
