Looking really good John, the re-bar & damage is very realistic, nice to see you have your mojo back.
Thanks Graeme, enjoyed do the rebar, certainly helps with the detail.
Thanks Gerry, should get back to this once the other build is under way.Looking good Mr Race :thumb2:
Cheers Andrew, bench is a bit cluttered ( no change from normal ) but as I said to Gerry I should get back to this soon. Appreciate you both looking in.Coming on nicely John.
Keep up the good work.
Thanks Andrew, just been doing the branches so nothing to really show.Looking good John. Good to see this back on the bench.
Yes Paul, head light and rear light glasses.Sum'pin on the clear sprue you don't want to lose?
Andy getting snow to look right is not easy, I've found that using Sculpamold being white you can do a wash over it. When the PIS is used it will cover most of it, just showing a a hint of muddy .Great to see this back on the go Mr.R. :thumb2:
It`s looking very nice indeed,i`m particularly liking the muddied snow,snow is something i`ve struggled with over time....... even with using the "Precision Snow" stuff!
Good watch this is mate,
Andy
Excellent JR.........you might fix that rust in place with a light low pressure dusting of thinned flat clear before the hairspray treatment. Just a thot Sir. Rick H.
Hi John
I remember this well. Real rust :thumb2: . I look forward to the completed trees.
Glad your back on this, was looking forward to seeing your trees.
Have to agree with you Gerry, the masses of needles on a Scots Pine are a problem.Using some foliage dark enough should be ok. Normally I use Sea foam trees that I grow for Silver Birch , but these are so different .Managed to day to do another coat of latex on the wires, and drilled out another truck and painted it. Going to be at least 3 days before I can start to paint the branches as the latex seems to take ages to dry.Looking very realistic there now. :thumb2:
I've always looked at trees as being 'difficult' items to get 'right' - I find that with me, they come out all the wrong shape!
