Katyusha rocket launchers, which were invented in Voronezh, were mounted on many platforms during World War II, including on trucks, artillery tractors, tanks, and armoured trains, as well as on naval and riverine vessels as assault support weapons. Soviet engineers also mounted single Katyusha rockets on lengths of railway track to serve in urban combat.
The design was relatively simple, consisting of racks of parallel rails on which rockets were mounted, with a folding frame to raise the rails to launch position. Each truck had 14 to 48 launchers. The M-13 rocket of the BM-13 system was 80 cm (2 ft 7 in) long, 13.2 cm (5.2 in) in diameter and weighed 42 kg (93 lb).
The weapon is less accurate than conventional artillery guns, but is extremely effective in saturation bombardment. A battery of four BM-13 launchers could fire a salvo in 7–10 seconds that delivered 4.35 tons of high explosives over a 400,000-square-metre (4,300,000 sq ft) impact zone,[3] making its power roughly equivalent to that of 72 conventional artillery guns. With an efficient crew, the launchers could redeploy to a new location immediately after firing, denying the enemy the opportunity for counterbattery fire. Katyusha batteries were often massed in very large numbers to create a shock effect on enemy forces. The weapon's disadvantage was the long time it took to reload a launcher, in contrast to conventional guns which could sustain a continuous low rate of fire.
Development[edit]
BM-13N Katyusha on a Lend-Lease Studebaker US6 2+1⁄2-ton 6×6 truck, at the Museum of the Great Patriotic War, Moscow (2006)
BM-31-12 on ZIS-12 at the Museum (Diorama) on Sapun Mountain, Sevastopol
Katyusha on a ZIL-157 truck
Reloading a BM-13
An M13 rocket for the Katyusha launcher on display in Musée de l'Armée.
In June 1938, the Soviet Reaction-Engine Scientific Research Institute (RNII) in Moscow was authorized by the Main Artillery Directorate (GAU) to develop a multiple rocket launcher for the RS-132 aircraft rocket (RS for Reaktivnyy Snaryad, 'rocket-powered shell').[10] I. Gvay led a design team in Chelyabinsk, Russia, which built several prototype launchers firing the modified 132 mm M-132 rockets over the sides of ZIS-5 trucks. These proved unstable, and V.N. Galkovskiy proposed mounting the launch rails longitudinally. In August 1939, the result was the BM-13 (BM stands for боевая машина (translit. boyevaya mashina), 'combat vehicle' for M-13 rockets).[1]
The first large-scale testing of the rocket launchers took place at the end of 1938, when 233 rounds of various types were used. A salvo of rockets could completely straddle a target at a range of 5,500 metres (3.4 mi). But the artillery branch was not fond of the Katyusha, because it took up to 50 minutes to load and fire 24 rounds, while a conventional howitzer could fire 95 to 150 rounds in the same time.[citation needed] Testing with various rockets was conducted through 1940, and the BM-13-16 with launch rails for sixteen rockets was authorized for production. Only forty launchers were built before Germany invaded the Soviet Union in June 1941.[6]
After their success in the first month of the war, mass production was ordered and the development of other models proceeded. The Katyusha was inexpensive and could be manufactured in light industrial installations which did not have the heavy equipment to build conventional artillery gun barrels.[3] By the end of 1942, 3,237 Katyusha launchers of all types had been built, and by the end of the war total production reached about 10,000.[11]
The truck-mounted Katyushas were installed on ZIS-6 6×4 trucks, as well as the two-axle ZIS-5 and ZIS-5V. In 1941, a small number of BM-13 launchers were mounted on STZ-5 artillery tractors. A few were also tried on KV tank chassis as the KV-1K, but this was a needless waste of heavy armour. Starting in 1942, they were also mounted on various British, Canadian and U.S. Lend-Lease trucks, in which case they were sometimes referred to as BM-13S. The cross-country performance of the Studebaker US6 2½-ton 6×6 truck was so good that it became the GAU's standard mounting in 1943, designated BM-13N (normalizovanniy, 'standardized'), and more than 1,800 of this model were manufactured by the end of World War II.[12] After World War II, BM-13s were based on Soviet-built ZIS-151 trucks.
The 82 mm BM-8 was approved in August 1941, and deployed as the BM-8-36 on truck beds and BM-8-24 on T-40 and T-60 light tank chassis. Later these were also installed on GAZ-67 jeeps as the BM-8-8, and on the larger Studebaker trucks as the BM-8-48.[3] In 1942, the team of scientists Leonid Shvarts, Moisei Komissarchik and engineer Yakov Shor received the Stalin prize for the development of the BM-8-48.[13][14]
Based on the M-13, the M-30 rocket was developed in 1942. Its bulbous warhead required it to be fired from a grounded frame, called the M-30 (single frame, four round; later double frame, 8 round), instead of a launch rail mounted on a truck. In 1944 it became the basis for the BM-31-12 truck-mounted launcher.[3]
A battery of BM-13-16 launchers included four firing vehicles, two reload trucks and two technical support trucks, with each firing vehicle having a crew of six. Reloading was executed in 3–4 minutes, although the standard procedure was to switch to a new position some 10 km away due to the ease with which the battery could be identified by the enemy. Three batteries were combined into a division (company), and three divisions into a separate mine-firing regiment of rocket artillery.
For discussion only from Wikipedia.
I've always had a fascination for these weapons, the sound of a battery firing these is something else, what on earth it was like to be on the receiving end must have been hell.
This one a "T-40" T-60 were produced with BM-8-24 Katjusha rocket racks mounted instead of a turret. This version provided a mobile mount for a 24-rail multiple-launch rocket system, firing 82 mm unguided rockets.A total of 12 T-40 were converted into this model in autumn 1941 .Widely photographed in the Operation Barbarossa , where many were knocked out and rarely seen after the end 1941.
Box Art :
A quick look at the sprues showed very little flash, I was expecting to see a lot more.
Not detail on those rockets that more modern manufactures would have done , but good enough.
Detail really not bad for the price.
According to Scale mates this first came out in 2006 and was classed as a T60.
Seats now available through normal channels co Mrs Jones Ticket agency.
Dzhon
Development[edit]
Reloading a BM-13
Box Art :
Dzhon
