Says on the box Tim TOOL ZONE. When I was looking they all seemed to be the same photo, so just another name on a mass produced item.Nice hand vice john. What make?
HI John whatever do you use that for ?Says on the box Tim TOOL ZONE. When I was looking they all seemed to be the same photo, so just another name on a mass produced item.
Thought it was forJust arrived in the post room here at Race Towers.
I remember Jim talking about them some time a go.
Not quite Chris. The pegs are put in the holes where required, and then the knurled nut tightened to hold the workpiece between them. It is a bit like a hand held Black and Dekker workmate……CHEERS Tim but vid wont play on my p/c but i gather its for holding things in the holes yea ?
chris
OK TIM THANKS for putting me right on that as for a moment there i was thinking like ow m8 Bob lolNot quite Chris. The pegs are put in the holes where required, and then the knurled nut tightened to hold the workpiece between them. It is a bit like a hand held Black and Dekker workmate……
I’ve had one of those for years, thought it would be useful for holding models, but I didn’t find it to beJust arrived in the post room here at Race Towers.
That’s exactly why I bought one (from a local art supplies shop, IIRC), but I found it got in my way more than it helped me paint the models. Also, not being able to set it down didn’t help. I thought about sawing off the rounded bottom of the handle and adding something to it that would let the whole thing stand upright, but never did get round to that.As I’m sure you know Jakko, they are used quite often by large scale figure painters to hold workpieces so they are not touched during painting.
Look there is no need to be rude about Cheese, esp Russian Green .:smiling3::tongue-out3:Thought it was forgrating your collection of russian moscow green cheese
There was a version with a bench fixing, I nearly went for that. But as I wanted one to hold figures a fixed one would be in the wrong place on the bench. I'll give it a try when the filler arrives, might be good, or it might:smiling3: be one of those tools you thought was fantastic. :smiling3:That’s exactly why I bought one (from a local art supplies shop, IIRC), but I found it got in my way more than it helped me paint the models. Also, not being able to set it down didn’t help. I thought about sawing off the rounded bottom of the handle and adding something to it that would let the whole thing stand upright, but never did get round to that.
You could just make a suitable sized hole in a block of wood and place it in there when you’ve finished JakkoThat’s exactly why I bought one (from a local art supplies shop, IIRC), but I found it got in my way more than it helped me paint the models. Also, not being able to set it down didn’t help. I thought about sawing off the rounded bottom of the handle and adding something to it that would let the whole thing stand upright, but never did get round to that.
Funny about tools isn’t it….I’ve got one of those vices (had it for at least ten years) and have probably used it about five times John…..I just find my small record vice clamped to the bench more useful….it probably isn’t, that’s just the one I’m used to using :thinking: The hand vice and pin vices I have do get used a huge amount though…I find this a very useful tool. Here is mine which has had a certain amount of wear, as you can see.
If I want to use it hands free, then the handle very simply unscrews.
For even more solidity I often screw the top bit into my little desk vice. This makes a very solid base for sculpting or painting models.
Then I would have find a place for a big enough block of wood, and if you’ve seen my pictures of what my work area looks like, that’s going to be unlikelyYou could just make a suitable sized hole in a block of wood and place it in there when you’ve finished Jakko![]()
