29-31 Hampton Street. London's East End....Sept. 1940.
Hi Ron
That's a great little shelter. I saw a programme on tele a few weeks ago showing how they were erected. Interesting.
Your supposed to be resting the eye Chris . Have you managed to get any more pain killers yet ?
HI John i am resting it as ive got it closed while i read with my right eye an no no pain killers yet an wed goin to ask at docs if they can let me have a strip till my prescriptinons come through on friday if not then i'll have to go to chemist but cant at the moment as i dont want to drive even though my sight is now ok but hos said it would be a few days till i can drive so im bein safe till about friday or so to be on the safe side
Starting to add the roof spars.
The spars are balsa, cut down from 1/16" sheet stock. I cut down a coffee stirrer for the ridge board. Far stronger than balsa.
Cheers.
Ron
Thanks Tim.
Gerry. I can't do the flashing until all the necessary elements are in place. Which, as I'm sure you have observed, they have yet to be fixed in place.
Thanks for the input chaps... :thumb2:
Roofing nearly completed.
Terraced houses didn't usually have fascia boards, but simply showed the ends of the roof spars. Had I adopted this option, I would have the extra work of sparring out the whole roof, the same as the outhouses, only to have them hidden! No thanks.
So, to be simpler and quicker, I fitted a length of fascia board to the bare spar ends. Over thick, I know, but it will either be destroyed or hidden by the undamaged sections of roof, so the 'Error' won't be seen.
Cheers.
Ron
I'm envious of your ability to knock up stuff out of stuff :cool: :thumb2:
Looking superb as usual.
Cheers.
Ron
Ron, I was joking - the level of detail that you're putting in here - what's the wall paper pattern going to be? :surprised: :tongue-out2:
Hey Ron. If you're going to put paper up, can I ask that you don't use any floral patterns at No29 please? I can't stand all that flowery stuff!
Thanks chaps.
No wallpaper Dave. There will be hardly be any walls to hang the stuff on! ;) ;)
Nearly there Rick.
A bit more faffing about then out with the 'Digitus Wrecktus!
I've added the lead flashings, a bit of slating and just a couple of rows of slate battens to the outbuildings of 29/31. These are now more or less complete and ready to be trashed....
Paper slates and battens. The battens are very, very thin! I painted the paper as a sheet first. Once dried, the paper became stiff and strong enough to cut the strips without fear of tearing the stuff. I use a Stanley Knife (Other makes are available :upside:) for this type of work, as both paper and card eat scalpel blades for fun.
Kitchen foil lead flashing cut into 1/8" strips, painted and then 'Stroked' with a wire brush before bending and gluing in place.
Terrace roof to finish next.
Thanks for looking in.
Yours,
Syrenn Souwndin
Nearly there Rick.
Yours,
Syrenn Souwndin
Ron
Simply outstanding!!! Almost seems a shame to destroy it all....
ATB.
