Panzerwerkstattzug (42)
minitnkr
Charter member of Rabble, bed# 105
Paul
Dayton, OH USA
I'm going to attempt to model this unit including Group Fuhrer, Werkstatt, Werkstattgruppe fur Nach. Gerat, Bergestaffel 1, Waffenmeisterei, & Bergestaffel 2, elements' vehicles in 1/87 scale from various makers. The period will be 1944, so some substitutions will have been made to the TO&E. Not all are soft skins as there will be two Bergespanthers & a BergespzrIII. Because a lot of the models are in various states of completion I'll only blog the more complex builds. BTW, Minime Rick donated several of the hated resin to test my tolerance for pain. As I am modeling the unit I'll try to keep everything under this thread unless directed otherwise. No dio planned as yet due to model RR taking all the man cave space.
How nice of him Paul ;) Very thoughtful.
Shall grab a seat or stand if the room is short of space .
Sounds interesting as always, so I’ll keep an eye on this if I may.
Thank you for your support. I need to do a bench tidy first to make room & get the OD stuff out of the way.
Hi Paul
I'm in. I enjoy your mini modelling.
I am looking forward to this one Paul......don't tidy that bench, it will take you twice as long to do the builds, I have that prob. every time I clean up and put things "away" :thinking:
......and so it begins......
Already broke one removing from block f...............................!!!! Three for four so far.
Once again the dreaded RESIN monster has reared its ugly head!!! This is why I dislike, intensely (HATE) resin kits.....all I can say is I'm relieved to say it is your problem and not mine. There is no reason for any resin kit manufacturer to leave 3 tons of excess material attached to the most delicate part of the kit...........but that's what they do. A test to your skill level? I think not! It's B.S.........another Whiskey bartender!!
Not to worry Dzohn/Rick, I just put away the US stuff and cleared off the paint locker. Also, I think there is a missing sheet of instructions. There is no mention of the load bed or where it might attach. There is no mention of adhesive or where it might be applied. I'll figure it out, but some location pins/holes/tabs/slots would have been helpful. Luckily I have some ref. pics in my morgue and some dark chocolate covered cherries to help.
Quick question: is the title of this thread supposed to be “Panzerwerkstattzug (42)”? If so, it’s probably not too late to change it :)
Thank you Jakko, just so, must have fatfingeredit, but I don't know how to change it.
Edit the first post in the thread, if you still can, that will also let you change the title. If not, report your own post (with the “Report” link at the bottom of it) and explain how you would like a moderator to change the title :)
Got to love German compound words. Hope I wrote it propa!
Perfecto sir, thank you.
Or just send me a PM. I'm normally never far from a PC.
Your welcome
Some progress pics. Parts cleanup & some paint on Anh116.
Some plastic & resin assembly & reassembly, details & paint. ROCO MB4500, a couple commercial 3tonners from Rick being militarized, a MB 1.5 ton bus resin model & ambulance/bus conversion, also from Rick. As can be seen, not much of a tidy. C&Cs welcome.
