Let me sing the praises of some tools I don’t use much, but which I wouldn’t want to do without
To adapt the rear suspension to the nose-dive attitude, I needed to cut free the arms from the mounting plates that they are moulded integrally with. That’s a tricky job because it needs sawing in tight spaces on a part that’s perhaps 4 or 5 cm long, at a quick guess, and basically needs to be cut in half at that. To hold something like that, a fully adjustable, modeller’s vice is a very good tool to own:
Because of the swivelling upper part, you can position it as you want for most convenient sawing, drilling, filing, etc. unlike with a standard, fixed vice, where you have to adapt to its position. It’s not that cheap, but if you convert or scratchbuild things, you’ll probably soon find yourself glad you bought one instead of another kit for the stash
The other is one I’ve mentioned before:
Saw blades for a knife handle, made from the same steel as regular modelling knife blades so they don’t twist or buckle. They’re thicker than a typical modelling saw, but their strength means they have very low height — which I needed here to get the saw into where the cut had to be made. A regular saw would not be able to get past the axle bearing, or at least, not without sawing at an angle instead of right along the mounting plate.
After a little work sawing, and filing the backs of the mounting plates flat, I ended up with:
(And then I did the other one too, of course
) To make up the thickness of material I had sawed away, I filed the rounded bits off the suspension arms as well and replaced them by punched plastic card discs, 0.5 mm thick and 4 mm diameter. The mounting plates, I glued to the chassis with a 5 by 7 mm rectangle of 0.75 mm card between them to make the plate I had removed between the suspension arms:
I then went and dry-fitted the subframe that goes below the suspension mountings, and found it wouldn’t fit correctly … Turns out I had the mountings slightly too far to the rear, due to not having any locating pins anymore, I suppose. Easiest solution: slice them off again with a knife while the glue was still wet, then stick them to the subframe instead:
That way they’re guaranteed to line up with it, at least
