Because the left-hand mudguard over the track was bent on the real thing, I decided to replace it with brass. That was mostly a matter of measuring up the kit part and cutting a brass rectangle to match, cutting two notches to facilitate bending, then bending the outside edge down and adding the two bends to get it into shape.
The kit includes two sets of mudguards, one for the armoured cab and one for the soft-top. Here are both, plus my brass version:
I then cut the actual mudguard bit off the one for the armoured cab, so I could superglue the brass one in its place:
I chose to cut up the one for the armoured cab, so I can still compare to the original for details like the ribs on it that still need to be added. I annealed the brass first, though, to hopefully make it bend more easily later, which is why it’s changed colour.
Next, I glued the two mudguards to the floor and out everything in place on the chassis so I could align everything correctly:
