Insta Sno
Jack L
Cheltenham
Bought this a while ago (within 12 months I believe) and come to use it finally, and it's rock solid. Believe is should be a paste? Has anyone had any luck 're-activating' it?
Hi Jack
If it's the stuff from Precision Ice and Snow then I think, when dry, it will soften with warm water. I'm not certain so I'd take a small lump and try it.
Hi Jack
That's the stuff. Thanks @Jim R , I will give that a go.
That happened to mine as well. I just mixed some water back in until it was useable again. Mind you, when it ran out I replaced it with baking soda mixed into PVA glue and slightly diluted with water. Hard pushed to spot the difference after it dries.
