Don't know if it has been reported earlier...
RFM released the Leopard 2A6M CAN with bar armour.
(All pics from RFM and for discusion only)
An early version - to get the later version first you add the 'Barracuda' camoflague and then for the later version you add the short bar armour... But still looks a great kit.
As an aside if you are going to build it, construct a short length of track first along with a dry run of the drive sprocket to make sure they actually fit the drive sprocket.
I had to add a 1mm shim between the sprocket on my build to take the MENG Leopard track - a ten minute job.
