More exciting things on the base.
The first thing to do is rough up the Foam Board to give the Sculptamold a key . Followed by an application of full strength PVA.
I allow this about 15mins to start to skin and then add another small amount to some Sculptamold .
Then add some COLD water ( I used warm once only to find the heat caused a reaction with the plaster and set if hard before I was ready :smiling3: )
Mixed up well , adding more water if you want a very thin coat, but remember the more water you add the longer it takes to dry.
Then apply as required, I've left the center as this will have a very thin coat of filler with some sand added to form the river bed. Yes I know little will be seen if I add to much snow, so have decided to just add a little when the time comes.
Close up of one side .
Still a lot to do to this, forming the rock base as the layers are built up.
Left to dry fully before any more additions, so while that takes place I'll carry on with the tracks.
I've some Basswood on- order and tomorrow while gardening I hope to find some suitable lengths of round stock for the massive timbers.
This is the actual photo I'm using showing a KV1 .
Thanks for looking in, comments welcome.
John.
John.
