Tamiya 1/350 Fletcher DD445 Destroyer.
Here's a little more Si.
The torpedo tubes were also made up as separate assemblies as they'd be in the same gray as the superstructure. The molding of these were superb with nearly no seam lines. I don't think there are any piping given in the PE set or if there were any visible along the tubes. Will have to check references. The covered control dome doesn't have a door so will add one.
The mounts are on poly capped pedestals too and easily fits into sockets in the platform deck between the funnels.
Hi Richard
Turrets and torpedo tubes looking good.
Looking good Richard!
ATB.
Thanks Andrew, I've stopped this for a while to add PE railings for the 1/700 Clifton Sprague...forgotten how tiny they are and just got the bow area done.
Richard whats happened to this build ?
chris b
Hi Chris, I'm afraid I lost mojo on this and am concentrating on the Constipation and the other dioramas for the moment. Will come to it when I get a boost from another viewing of Greyhound.
