Nice one Paul, Chris will soon have those turrets spinning roundChris are these any good link
HI Scottie many thanks for looking for me much appreciatedChris are these any good link
CHEERS Tim i'll ask himI’ve had a look around, but can’t find anything. However, I don’t know what the proper name for those sort of gears. Strikes me that to look for what you need, you need to know what it is called Chris. Might be worth dropping Dave award a PM. He is a trained engineer and might know exactly what you are after.
CHEERS Pete but my pc wont load the adobe player so i cant look at the site im afraid
cheers gary very good idea but im gonna have a look at an idea ive just thought up cheers for your helpHow many degrees does the turret need to turn thru ?
If less than 180 you could just use a servo motor to rotate it, like the servos used to raise undercarriage in r/c planes
Looks a great site Pete, must be something there for Chris .OK, just go to www.https://www.hpcgears.com/ and browse about. Or you could email them and ask if they have what you want - if you send them a few pics of your ships they might even offer you a sample...
Another thought - do you actually need gears? I was thinking if the motor had a rubber tyre (model car tyre?) on it's shaft, running against a smooth plastic ring inside the turret, would that work?
