You can use most paints over most others with no problems, whether different types (acrylic, enamel etc.) or different brands. If in doubt about anything paint-related, you can always do a quick test — in this case, paint a piece of leftover sprue with the paint you want underneath, and when it’s dried, put the second over it and see what happens.
The main thing to keep in mind is not to mix paints of different types: don’t mix acrylic and enamel paints to make up a colour you need, for example, as it’s unlikely to go well. Different brands of the same type of paint can normally be mixed with no problems, though some may cause trouble — again, if in doubt, just try mixing one drop of each on a palette (like a glazed wall tile, the inside of an old jar lid, etc.).
