There is, but it is just called a paint brush Bob…….Thanks, Paul, so you still need a compressor with it then, and there's no such thing as a pure gravity-fed one??
Sorry, I meant to say that the compressor doesn't have a tank!I see.
I thought it had a small compressor?
SO, put my brain in order if possible please (I am a ficko)....
I just assumed a "Gravity air sprayer" doesn't require a compressor Right/Wrong?
What exactly does a gravity-fed one look like please?
Excuse the dumb questions :smiling3:
I agree about the 186. My first compressor was an AS186 and it did me well and lasted well over 5 years representing great value for such a cheap Chinese product. It makes a perfect first time compressor for anyone.My Iwatta compressor is tankless as well and I experience no pulsing whatever. Not one I’d recommend to a novice though. Its more expensive than an AS 186, and for learning, the 186 is more than adequate.
Looks fine to me. Worth it for the compressor alone. Don’t worry about the leak around the gauge that the seller mentions, that should be easily fixed with a little plumbers PTFE tape.As funds are low, Is this used one worth a punt?
https://www.ebay.co.uk/itm/165566820941?hash=item268c8d324d:g:CgQAAOSwRWpixtr~
or are there any used ones on this forum?
Yes, I have earmarked that one for £65.Considering your first choice was second hand 70quid with postage this one also second hand i dont know what kind of max bid you've made but plus best part of seven quid postage ? You can get the same switzer airbrush compressor kit brand new Inc postage 63.99 or 64 .99 sorry cant be bothered to go back and look on flea Bay.
Personaly I'd go brand new every time .
Bear in mind that those airbrushes are the generic cheapo Chinese ones, and you'll probably want a better one (H & S, Iwata, Badger, Bartsharp, etc) fairly soon.right, I've put a max bid on this one now....
https://www.ebay.co.uk/itm/115460040462?hash=item1ae1f4670e:g:NeIAAOSw~zNiyn1y&autorefresh=true
won't hold my breath :anguished:
