Well, an interesting couple of days. Yesterday I cut up some decals for 1/48 Corsair IPs for some instrument dials and added them to the bits of plastic I'd added to the cockpit sides.
I'd also added some punched Plasticard discs to the back of the IP - they don't line up with the dials on the other side, but neither do the ones on the decal supplied in the kit! I drew the line at adding wiring, that's a scratch too far for me. Unfortunately, and rather stupidly, I then decided to add some of this stuff
to the crew. They call it a dipping formula but it's a thick jelly that would obliterate all detail, so I brushed it on with some water added. I was not pleased with the result:
It's turned pink in places, and is too dark in others. It won't wash off, so unless I strip all the paint off, it'll have to do. Annoying, I want to get this cockpit finished so I can start building a Mosquito! When the IP decal has dried (it's on its third dose of MicroSol at the moment) I'll see if the crew can be added after the fuselage is closed up.
An very enjoyable day today though - I went to the De Havilland Museum, which is absolutely excellent; 3 Mossies including the prototype, a couple of Vampires, a Horsa, Hornet Moth, Cierva autogiro (not sure why that's in there) Queen Bee, a Comet 88 replica, a Comet 1A airliner fuselage open to walk through, Tiger Moth, Chipmunk, Sea Venom (partly dismantled), Sea Vixen, Heron, Dove, DH125, BAE146 open to walk through. Many of the cockpits are open and have steps alongside so you can get up close (but not of course sit in!). I'll post pics later as I took my big DSLR and both the batteries are refusing to charge at the moment and my computer has decided it doesn't want to play nicely with my card reader.
One of the things I wanted to sort out is the cylindrical object on the panel that's on the forward side of the IP/pedal assembly, that most modellers assume is a fire extinguisher and paint red. I think that it's a strange location for an extinguisher, and if it is an extinguisher it surely wouldn't be red until well after the war. Poring over the cutaway drawing in the Haynes manual for the Mossie, there's no fire extinguisher but there are several portable oxygen bottles. I asked one of the volunteers at the museum, and he also thought it wouldn't be an extinguisher, as apart from being poorly accessible when the navigator is seated, any enemy fire coming through the nose might set it off, which would make the cockpit rather unpleasant. I suppose bullets hitting an oxygen bottle would also be pretty undesirable, but wouldn't result in a poisonous atmosphere. Then I had a good look at the prototype, and that does have an extinguisher (brass, Pyrene) in that position. Finally spoke to a volunteer who'd been heavily involved of their B35 Mossie - he told me that the wasn't aware of them having any hand-held extinguishers, only the ones in the engine nacelles, and the oxy bottles are on the starboard fuselage side, so the clip is probably there to hold the Nav's Thermos flask.
So, whatever it is, I painted it black.
Here's the IP, decal not dry yet:
Revell haven't provided a back cushion for the navigator; I was counting on that being hidden by the crew figures, but after the wash disaster I'm considering leaving them out.
Another thing that seems to be lacking in all the kits I've seen is some indication of the crew entry hatch inside the cockpit, and all 3 of the Mossies at the museum have a clear circular 'window' let into both the external hatch and the corresponding hinged panel in the cockpit floor. Revell have moulded a circular outline in the right place, but don't provide a clear piece to go into it, and they've also moulded a similar outline at the front of each bomb bay door - what's that about?
I'm thoroughly confused, maybe I should just stop over-thinking this build and just start gluing parts together.
