John I had my PPP for a couple of years and it does go off and get a bit hard below the nozzle screw cap. I use a small screwdriver to get the hardened bit out and then found it useable again. Feel the tube itself. If it is pliable then it is possibly the same as I encountered.
Have not used Vallejo, and sounds as though you recommend iit. I guess it stays soft in the tube? Does it go on and smooth down better than Perfect Plastic Putty generally?
