Those horses do look very good indeed!!
Love the horses.
Thanks,
Need to get round to finishing them all.
Love the horses.
...... and I thought he was deciding what to plant in his new greenhouse :smiling:The Italian officer is for scale reasons only.
Got one of these on the go myself currently Ian,(although stalled due to my commitments to various Flying fing GBsHave had a few cooler mornings here so making the best out of the time before it warms up.
CA glue and 24C with 98% humidity is not a good mix. Neither is model building/painting with sweaty hands!
So mornings it is:
Started off just building this Old Airfix Chevy CMP tractor Light Mud is sprayed, the "mickey mouse" camo is in true to life brushed on.
Needs a bit of mud and dust but getting there.
Then I remembered I had a Tamiya 25lb'er The Limber is used elsewhere and the Quad..... mæh. later maybe. Then in the bottom of the box was an Eduard PE set for the darn thing! So a lot of swearing later:
Apart from some of the bits are silly small and best guess on how they fold and where they are placed the hardest part is the aiming sights which, as well as the three kit parts needing PE they also need to be altered!
Coffee time!
Blimey that's another level of awesome!Hi everyone
Well instead of a weekend it took nearly three weeks to do. So first off we did a primer coat of Tamiya's Red Oxide primer. Then followed a couple of sweeps of hairspray. Then a little bit of subtle chipping. Another layer of HS. Then the banding was masked off and three layers of acrylic yellow was added.
This created a nice thick (as in paint thickness) band which when chipped looked like the real paper banding so was happy with the look
Matt varnish was then added. Once dry, a layer of light dust oil was washed on. Then two further layers of different shades of dust oil sponged on. Then a moist scouring pad dipped in thinner was gently dragged across the surface to create fine scratches. Raw Sienna oil added to the yellow banding. Sepia oil was splattered all over followed by a final dust oil wash on top
So once added to the model they should look like these
Happy modelling
Showing those Pin Vise's with the models gives a great idea of the size you work in Paul. Respect from me working in that scale .Putting off painting US Inf. by prepping kettens by drilling out bogies & general cleanup before detailing & paint. Oh, and adding mesh to cooling grills on Jagdtiger.
I'm with Jim on this , another one who thought he's building greenhouses now ! Great work Steve, what glue are you using please . Mr T would indeed be proud of you .Hi everyone
Doing my first complete scratch built model (except for the wheels). Mr T. always urged me to do one but its only been recently that I have had the nerve to do it. The biggest lesson I have learnt is that if you begin 0.1mm out then by the time you have finished a section then you will be 0.5mm out so precision is the name of the game. Its in 1/35 scale and the body and chassis are nearly complete. Then it will be onto the internal detailing. This is the look out section about 75% complete.
The Italian officer is for scale reasons only. Happy modelling!
Cheers Neil. I appreciate your commentsBlimey that's another level of awesome!
I am just using Tamiya thin. I tried some of that clear plastic glue but couldn't get on with it. There are a couple of glue seepages but nothing major. Thanks for commenting mate.I'm with Jim on this , another one who thought he's building greenhouses now ! Great work Steve, what glue are you using please . Mr T would indeed be proud of you .
and yes i did drop some pliers on a bit of railing,sure you can spot it.scalemodelling.co.uk is a privately operated online discussion forum. All content posted by members reflects their own views and opinions and does not necessarily represent those of the forum owners or administrators. While reasonable efforts are made to moderate content, no responsibility is accepted for user-generated material. By using this site, you agree to comply with UK law and the forum rules.
