Valeron's 1/35 ICM KHD S3000/SS M Maultier
Valeron
Here is my entry for this build. Thanks for organising it Dave.
I'm looking forward to this and hopefully I can complete my first non aircraft and non 1/72 model, which is all I've managed to complete since re-starting this hobby in January this year.
It'll be a slow start as I'm still behind on my Mossie.
I've found a rogue tiny piece of plastic in the box so I'm to have to carefully check the sprues to see if it has broken off from somewhere.
I haven't decided on colour schemes yet,20220901_071505.jpg20220901_071623.jpg20220901_071637.jpg20220901_071944.jpg20220901_072018.jpg20220901_072043.jpg20220901_072103.jpg20220901_072120.jpg
Mike,
the key to all ICM softskin builds is to get the chassis square! The flatpack chassis can be fiddly to put together, but getting it true is the best start! ( speaking from many ICM truck builds! )
Mike,
Thanks for the tip Dave. I've been looking through the instructions and see what you mean. Getting the chassis wrong would mean rework later when I try and attach the upper body.
My only other experience of a vehicle was an aborted build of a Tamiya 1/35 Achilles and the chassis was simply a solid box shape which needed no construction in itself.
Mike
Mike
ICM models do tend to be a bit over engineered, with a lot of tiny parts, including detail that will never be seen ( engines particularly ), but the fit is normally spot on, with little clean up needed
The difference between building a tracked, armoured vehicle kit and one of a soft-skin cargo vehicle is huge — armoured vehicles usually have simple hulls, frequently moulded in one piece like your previous effort, that make it very easy to get things square. Trucks … not so much, a lot of the time. Like Dave says, take care to get the chassis right, then most other things will likely fit well enough. If you get it warped, though, a lot of things will probably get thrown out of line.
I'm in for this Mike as I got one in the stash. Have fun building it!!! Did you find out what the piece in the box is???
Allen
I've found where the tiny piece of lose plastic in the box has broken off. I won't be a problem to fix I think.
I'll have to be careful though as the model contains many delicate pieces like this.
Nice choice Mike. If that broken piece is difficult to mend I think it could easily be scratched from a piece of suitable diameter wire.
We have an engine. It went together pretty easily. I'll do a little more cleanup when it is fully dry then prime it in a day or so when I'm priming my Mossie.
I'll then brush paint it with Vallejo model colour paints. The colours recommended in the instructions are gun metal, steel but mostly semi gloss black.
I have the former two but with regards to the black I have a flat and a gloss black. Vallejo don't seem to do a semi gloss black and I'd rather not purchase another pot of black anyway.
I was thinking a mix of both my blacks or flat black with a satin varnish which I also have.
It isn't really that important as the engine will be covered but I'm here and learning all the time so was wondering what people's thoughts were on the semi gloss black solution.
Mike
Flat black would be my first choice as road dust would shorty take care of the semi.
Mike,
I will watch this one, I built one of their maultiers a while ago. As has been said already take your time with the chassis the rest will fall into place.
Mike, if you want to build this as the kit mfg. recommends, mix half flat and half gloss and you will have your semi-gloss black without making another purchase. you won't need the varnish. :thumb2:
A bit of progress. The chassis is on its way. The engine is only dry fitted for now. The chassis seems square but time will tell I guess.
Looking good Mike. Like many of us you have built the engine and yet it won't be seen. Often though the engine, at least the lower parts, is integral to the chassis.
I've slowed down a bit on this build as I got behind on my Mossie. I should be back on this one next week.
