Use either, depending whether you want to use a rattle can (TS17) or airbrush/hairy brush (X11).Quick question.
Little bit puzzled by this. Is it telling me to use ts17 or x11?! Ones a spray can the others a paint. Little bit confused.
Is this a clear fairing? Enjoying your enthusiasm ! Have fun .......![]()
Tamiya x-20a thinners are for their acrylics, so probably won't shift this.
AK say use their odourless thinners, which is just turpentine so could probably be gotten cheaper. Especially if only for clean up.
Did you gloss coat first? Seems an important step.
And then you let the panel liner flow along the details.
Even clay washes have a time getting off matt paints, and they're water soluble.I didn’t glass coat first which after doing some research could be the issue!
