Andrew that's looking very good, don't know how you do the mottling, but it looks good .
Looks very good with the mottling as JR says. At his age he needs to worry about “Clotting” lol.
Nice :thumb2:
That’s a good base for the top coat Andrew.
Geoff.
Evening Andrew.........just caught up to this after its disappearance, I simply lost track of it.......anyway good to see it's back on the go and you have made tremendous progress since I last visited....over a month ago. Keep it coming pard, she's looking down right sassy! :thumb2:
Nice progress Andrew, the mottling looks great, that's the next job on my F16. I've watched quite a few online builds where they use this, and the results look really good.
Looks excellent andrew , all it needs is some balkenkreuz and it could pass for a Luftwaffe night fighter scheme ! Its going to giv
Coming along very nicely indeed Andrew.
Andrew, no I had no idea how to achieve that finish. Not much call for it in Russian armour :smiling3:The video was good .
Lee's quite right about that subject , hopefully I won't have any !
Looking good Andrew.
Had a good catch up with this Andrew,
A very interesting read it is too :thumb2: ,that`s some process you went through,and it`s evidently given a great result.
Gotta say,i love the mottling you`ve already achieved........ a shame to cover any of it up!!:tears-of-joy:
Great stuff,keep it up!!:tongue-out:
Very Niiiiice!
Great stuff Andrew, thanks for explaining the process too :thumb2:
It’s tricky modelling an actual aircraft when there are limited photos. I think your approach is a good way to do it.
Geoff.
Very careful, skilled and thoughtful work. Mottled base is good. I agree that when a multicoloured top coat is used the second colour can so easily wreck the mottling. Your solution is first rate. It takes time but I'll bet the end result is worth it.
Are the masks made from multiple strips of tape or did you use a sheet of masking?
Really interesting stuff Andrew.
Looking very good Andrew. The underpaint has given a lot of interest to the top coat. Hope the green turns out as well.
Put it on quite thin Andrew. It doesn’t flow so much then. Shouldn’t be much of an issue on a 1/72 bird anyway……not so much to cover.Thanks very much indeed Tim.
I've pretty pleased with how it's turned out all in all. I'm planning to use some of that magic putty to mask of the grey for the green camo patterns - start with thin sausages for the edges and then fill in the gaps with lumps - but knowing how it flows if left too long I'll have to be fairly quick.
Thanks again.
ATB.
