No need to be nervous Chris. Your application of logic and talent for the build will see this one through no danger.
HI YES it all worked a treat but ive got to fit on the 12 watt speaker as the 3 watt not powerfull enough only trouble its heavy an wheighs in at 12 ozs but i will fit it in the centre of the deck so no rolling probs but wont really know till she's on the wet stuff but tommow i'll be fittin in the spks into the deck so gonna be busy
ATB
Chrisb
Is that the right way to go Chris? Are these speakers active, powered by their own amplifier, or passive, powered by an external amplifier? if they are active then you are doing the right thing, but if they are passive, then possibly not. As I understand it, wattage in a passive speaker isn’t the volume it can put out, it is just the maximum power it will handle. A passive speaker will need a more powerful amplifier to sound louder.
In HiFi, the statistic that matters is the efficiency (usually a percentage) of the speaker. A higher efficiency means the speaker turns more of the operating power into noise. In two speakers of identical efficiency 30 watts is twice as loud as 3 watts, by the way.
Another option is to fit the 3 watt into a box and then fit the box into the ship. A bit like a music loudspeaker. That way, all the noise is projected to the front of the speaker, focussing the output and increasing the perceived noise it makes.
WELL Tim all i can say is that the gent who built the unit said there is an ampliflyer in the gun unit that will up the power of the spk an im very happy with how it sound an it will be better when built into a spk box to ampifyi the sound
chrisb
an well ive got now just two wires to wire in the bow section an they are pos an neg to take power to the stern section for the shipfloodlites so wireing nearly done in the bow half horay lol
Chris
Firstly apologies for not keeping up with this, work has been very busy. As always simply amazing what is needed internally for something like this to work.
Keep it up!!
ATB
Chris
Keep it up!!
ATB
HI Andrew no need to apologies as you do have a look in now an again thank you an yes all this wireing is needed if you want what i have workin an i may have gone OTT but im happy that everything works so far but wheather it will all work when takin to pond is another matter as she is in for a rough ride what with all the bad rds about here an them bloomin humps as something like a wire or such could jolt lose an then the probs start but will see an worry about it at the time
ATB to you Sir
chrisb
HI GUYS well a bit more done on this gun fire unit an the main 12 watt spk bein fitted in in the deck S/S HERE just fitted it for size to see if it will go in ok IMG_7861.JPG
AN YES it will fit so ive started to build a spk sound box to get the maximim bangs IMG_7863.JPG
an bottom of the box built in but the spk can be removed an there is also the whooper sound unit an spk as well IMG_7864.JPG
This build has so much going on mate. Is it still going to float ;)
HI Scottie well it could be a titanic but ive now picked up the rear end section an i can just lift it so yes its possibe but the gun fire unit wont be any good without the spker will it an its just as well the gun unit is fairly light which will be fitted in tomorrow an then its should all work but the big guns only as the small will train an elevate only
an side view an tomrrow the big funnell an fan unit will be fitted back on if the gun unit is all ok an yes all this build is headdin towards the finish line an with this big sound box it should bang good
I have every faith in you mate.
JUST as well you have Scottie an thank you but im gettin a bit worried on how havey she is but may be needed to get her down to her water line but if she is to heavy ive always got the option of removein them keel wheights as they just bolt on so there is always a way out
ATB
CHRISB
HI ALL
WELL now for a big update an plenty of pics
an firstly the gun unit now fitted in in the stern section under the second funnel an it now all wired up IMG_7869.JPG
an both gun turrets turn an guns elevate an the knicker elestic works well to pull the small 3 inch guns back down im pleased to say IMG_7888.JPG
an both lots of guns now in down postion an aiming to port side an the gun fire unit worked fab an im very pleased but it was a bit of a head scratcher at times IMG_7889.JPG
an now some pics of the gun flash an it was very bright as it dazzelled me if you are lookin right into the gun ballels an the gun fire sound well jen could hear it downstairs so quite loud which is what i wanted IMG_7871.JPG
