Hi, thanks for the reply. Used colour coats on the hull so far, not bad. But so far not 100%. Will continue to use on superstructure.Hi Bob
Notice you are using colour coats paints. I have just invested in some (my first go with enamels since the Stone Age as well!) could you please let me know how you get on with these, especially if you plan to use them in an airbrush.
Also, you have a Woodhunter deck, I have used one on my Dreadnought build, laid the forecastle deck first and it started to lift after a couple of days!!! ended up having to spot glue it down again with CA. Had to do this with All the decks. Have you used one before? And if so, how did it work out?
This us how I use a wood deck ( 2nd time mind ). Firsr I paint the plastic deck by brush with tamiya X 22 varnish, there are others of course. After it dries spray paint the barbettes and hatches. Then fit the deck using wooden dowels, paint brush handles etc to slowly press the deck down, no issues yet.
