Tamiya 1/350 KGV plus extras
Hi Bob
Notice you are using colour coats paints. I have just invested in some (my first go with enamels since the Stone Age as well!) could you please let me know how you get on with these, especially if you plan to use them in an airbrush.
Also, you have a Woodhunter deck, I have used one on my Dreadnought build, laid the forecastle deck first and it started to lift after a couple of days!!! ended up having to spot glue it down again with CA. Had to do this with All the decks. Have you used one before? And if so, how did it work out?
Hi, thanks for the reply. Used colour coats on the hull so far, not bad. But so far not 100%. Will continue to use on superstructure.
This us how I use a wood deck ( 2nd time mind ). Firsr I paint the plastic deck by brush with tamiya X 22 varnish, there are others of course. After it dries spray paint the barbettes and hatches. Then fit the deck using wooden dowels, paint brush handles etc to slowly press the deck down, no issues yet.
Tad more done
My PE experience so far is just the basics, sticking doors, hatches etc so for the first time I have attacked one of the kits AA bofors positionS, replacing a lot of plastic for PE.
The kit part
Cut the front parts off, added PE shields, rear railings, runners for the gun carriage and tiny gun sites
Can do better but for my first 'big' PE adventure I am reasonably happy. Got another to do so should improve again
Can see why PE is used as this is a big improvement over the kits very basic parts.
Hope it passes muster chaps
See, you can do it…….
great work Bob….looks fantastic. It will really add to the refinement of the piece…
Thanks Tim, took a lot of time but thanks to help from you and many others getting there. Found a ca glue I can use and the new tools are very helpful.
Don’t think I helped much mate….my advice was basically stop buying different glues and get on with it. What worked for you was finding the right glue LOL…..
Oh yes, You did, very simple advice but so helpful! Soaking cocktail sticks in CA before use!
Very impressive young Bob and you thought you couldn't do PE :thumb2::thumb2::thumb2:.
Well done and so small .
VERY well done Bob you the pe man now
Cheers Chris, much more to learn but having all the excellent advice and good tools help. Plus plenty of headache tablets and a close window to scream out off helps!!
Thanks John, been a bit of a battle for sure, way to go yet. The PE for the funnels looks fun, not!
ANY MORE PICS Bob mate as im enjoyin watchin your build ?
chrisb
That PE looks so much better that the kit's offering Bob. You have every reason to be pleased
chrisb
Here we go, slow but steady, both main battery directors, surprisingly there is no PE for the rear one
All 4 secondary directors, got better as I went along and Bofors AA batteries
Started adding simple PE shields to bofors, much more to do
Spent ages working on the funnel seams, next primer, just hope the dreaded seams have gone!!
Working on the huge bridge structure, added a few bits of PE
Finally enjoying using PE, at the moment at least!!!
Much appreciated Jim, I agree will bring much needed detail.
You'll have to change your moniker from Bobthestug to PE Bob.
OH Bob mate that bridge looks the dogs brillint work my good freind an pe looks really good an yes i know its difficult to fit but you have managded it very well done boyo keep up the good work as we all will be watchin
chrisb
Excellent work Bob. She’s going to be quite special once she’s finished.
Bob,
I really like where this is heading. that is some really nice PE work mate.
Cheers Paul, so far so good, way to go yet, funnels, masts and a complex looking pom pom pe set!
No way Jim lol, nice of you to say
chrisb
Bridge seams need work but looking ok, really must send u that rubber chq!
Thanks Tim, more fun to go, not glued fingers together yet!!
Today tackled my most complex PE yet, to others a walk in the park lol. One of the ships cranes. Lots of bending, twisting and glueing!
The Tamiya PE pliers were a god send, really useful tool. Not 100% but big improvement over recent PE stuff, will build the other crane slightly differently.
Not the cleanest but had a headache trying to attach the crane frame and the 2 cables, could not use CA as it would set too quickly so tried PVA. Bit messy.
