Thanks Jim, polishing the inside of the canopy has its advantages as holding it between my fingers I can add pressure against the finger as a backing when polishing. If it were the outside I would have to tape the inside and fill putty to strengthen it.Excellent work on the figures. You have certainly improved them a great deal. I'm glad the canopy worked OK. Polishing that "U" shape is difficult to do without cracking the plastic - I did just that and had to send off to the manufacturer for a replacement. Luckily the customer service was good. Do you find Blu-tack can leave a mark? As always great modelling.
I suppose that humidity and high temperatures where you live makes painting a bit of a lottery. You'll be used to it by now though. Looking good.The weather has been odd these few days so the paint behavior is erratic leaving a bit of orange peel
Thanks Jim, the oddity is hot, humid and cool rain all in the same day switching places so you can't tell when to paint gloss coats. :rolling: :smiling6:I suppose that humidity and high temperatures where you live makes painting a bit of a lottery. You'll be used to it by now though. Looking good.
