OK, I'm one of the world's great procrastinators, but I've run out of excuses not to start on this. The three figures are painted, and I don't want to start building the feature tree until the base is at least part-completed. So start on the base I must.
I started by cutting a 12mm ply baseboard - it's 12" x 11" (don't ask, I'm of an age that switches between metric and imperial as the fancy takes me).
Then I started sticking on layers of dark grey 25mm styrofoam using gorilla glue. Weights are housebricks wrapped in brown paper (for cleanliness) - a neat trick I pinched off my missus, who used them when she was a bookbinding apprentice.
Then I began chopping away sharp edges.
Then the shapes were further softened with a blowtorch.
You can see that the foamed glue has melted at a slower rate than the Styrofoam, so I've cut that away.
I'm now thinking about coating it with Sculptamold and adding foam clay rocks. Not sure about the order here - rocks first? Sculptamold first?
Just to emphasise that these rocks really are foam:
