1/72 HMS Iron Duke - Type 23 Frigate
Garry
That's coming on very nicely indeed. Apologies for getting very behind.
ATB.
Ps great pic of the sunset!
YES Garry it looks spot on very well done indeed an will you be fittin on the saftey nettin ?
Garry
ATB.
Thank you Andrew :thumb2: not to worry.
chrisb
Yes Chris, that is still to be done, the nightmare of PE :rolling:
HI Garry so you goin to use p/e for the flightdeck nettin well ive never used that as you say its a nightmare so i make my own nettin with steel or brass rod an aircraft alerons hinges an net curtain an when built its very strong an it will fold up or down but up to you on that good luck
an i see you got some block letters that stand out with the ships name ok well done as it look better than just a decal like ive seen some modelers use as your sort are like i use an like on the real ship great modeling
chrisb
chrisb
chrisb
chrisb
I really couldn't justify the cost of brass stanchions delivered to NZ, so had to go with the PE, it will be a real learning curve, but I will do my best :smiling:
Loving it Garry
Thank you Brian.
Thank you Brian.
YES Garry brass stanchions are really exspensive the why i make my own flight deck nettin
chrisb
This just gets better and better. A really fine job Garry. Love the helicopter.
Being the newbie I'm playing catch up so = page one and much reading. Looking forward to seeing how you got to where you are now!!
Making me feel old though. Iron Duke wasn't even in service when I left!!!
Well, I'm al caught up. (3 Hours). Well worth the time reading it all. Superb build. Excellent likeness. I can almost smell the grey paint!!!!
There was mention of a something about elephants ass or sonar unit. It is actually a towed array for long range detection of underwater contacts. Probably retro fitted during an upgrade dockyard refit. Which means whe deployed the vessel would be veeerrrrrry Sloooooow!
Digressing. Yup, agree with everyone. Brilliant job - more so considering you hadn't had a crack previously!! As they say in the RN. BZ (Bravo Zulu - well done!)
Bravo Zulu? - a most under-used coding in the Andrew - normally reserved for us and our ilk , and frequently used if I may make so bold (as well you know!) However the build is most excellent!
Steve!
HI Doug yes i was on about the elephants ass as my norfolk had it fitted but garry's shown a pic on his I/D where its not now fitted so look like its been removed
chrisb
Thank you for taking the time to look through my log, and thank you also for your kind comments.
VMT
Garry
Steve!
Thank you Steve very kind of you to say so.
VMT (I picked this abbreviation up from a Commander that I worked with, which I assume must be common in the RN)
Garry
