Hobby Zone Tilting 3-Drawer Module
Allen Dewire
Allen
Bamberg
Morning all,
While waiting for the high winds to cease, I thought I would do a quick review of this item. It's part of Hobby Zone's Modular system for storage and organization for hobbyists. The model number is HZ-OM02u and sells for around €24 to €29 online here. I ordered this online from Super-Hobby as no one else had it in stock. Delivery only took 3 days. The box is 34cm x 16.5cm x 5.5cm and weighs about 1000 grams...
What's in the box,
Laser cut press board and white laminated pieces too The frame and drawer frame sides are 6mm thick and the rest is 3mm thick. You get get 10 small Allen wrench screws and 8 strong magnets in a baggy, but no tools...The destructions are a single page and pretty easy to follow,
Construction is straight forward using wood glue. As a precaution, I went with using small brads/nails to strengthen various areas while assembling it. I drill holes 9mm deep using a 1mm drill bit. I did this to the main body and the side pieces of the drawers,
The 2 larger holes in the side panel are for the magnets to hold the modules together with another modular piece. The same with the top and bottom pieces when you stack them. Just be sure to insert them correctly so they stick together and not against each other with their polarity. I let every glue join dry overnight. I didn't use any clamps, just some weight in places till they dried. When dried, you just have to screw the Allen screws into the back of the drawers (above pic, left). The finished product,
It comes with 6 drawer dividers for you to use as needed,
They fit into the slots perfectly! I did a few tests with various paints and here are some results,
Large 23ml Tamiya paints fit, although their description says only their 10ml bottles will. AV, MIG, AK and the like fit fine. Another pic,
The AV bottles tops fit into the slots and the wash bottle fits in perfectly too. The combos are entirely up to your individual needs. You can also store everything from etch to tools or whatever in them and use the dividers accordingly...
I would give the unit a very good and useful rating. Maybe a bit pricey for some and there may be similar units from other makers that are cheaper. It's up to one's personal tastes. I recommend taking the little extra time to drill and pin it, along with the glue, to assemble it. Other than that, I hope this review was helpful and if you are thinking of becoming a member of Jimbo's (Jim R) TBC, then this unit is for you to tidy up your bench! Thanks for looking and all feedback or questions are greatly appreciated...
Allen
Very well written review Allen. Things often seem pricey at the time but considered over the time they last the price is much more reasonable. Having this on your bench would certainly count in your favour with the membership committee of the TBC (Tidy Bench Club)
This Hobby Zone modular system is available from John at the SMS.
I'd buy one of those if I had a clear space to put it...
Thank you Jim and glad you stated John has them in his shop! I was also trying to drum up membership in your TBC too, my friend...
Hey Pete, There are two words for your reasoning......Spring Cleaning!!! After all, it is April now...LOL...
Allen
Glad you like it, I have one and think it is overpriced tat. I had to sand the drawers to get them to fit in the cabinet and still they don't work very well. Shan't be buying anymore of the range. At a fiver it would be overpriced.
You must have got a duff one Bill. The HZ things I have, have all fitted very well. I'm surprised if it was that bad as they are laser cut but I guess they can go out of whack as well.
Sorry to hear that Bill. I found that my bottom drawer wouldn't slide very well in/out either. I changed it out with the middle drawer and then found I hadn't screwed an Allen screw far enough into the back of the drawer side. The screw head was hanging up on the runner trough. A quick twist in with the Allen wrench and the prob was corrected. If it was another prob with the fit or badly made parts, then I would drop a mail to Hobby Zone to let them know about it.
Allen
I have a three stack HZ set-up, a total of 23 image.jpgunits of various types and all of them went together perfectly. I love these units and the flexible modular design.
Horses for courses Barry. I also detest acrylic paint but many more people like it than don't.
Bill
As a result of my incapacity, mentioned in my about me post, I have this setup in the dining room, includes tilting modules.
I’ve asked them to produce a tilting unit with adjustable Allen key holes in the base to hold airbrushes in place.IMG_6935.jpeg
That's an impressive setup Mark.
Looks well organised. Good to have things close at hand.
