Chris, if you are trying to run 4 motors in parallel off one ESC then that could be the problem with the ESC overheating, using two ESC's will cut the current draw and should be OK. Not trying to tell you how to do your job just things I learned from flying electric powered model aircraft.
Andy.
Andy.
