Rick's 1-87 Scale Luftwaffe Airfield Fuel Tanker
Well here is the last update before paint flies......wipers installed, added rear license plate with a tail light stem, added the tow hitch, drilled out the headlight buckets for lenses and as a final touch, I bent the front axle to give the appearance of the wheels turned slightly to the left.....just to add interest on the diorama........oops, just noticed I need to install the driver's side mirror.
Rick
That's coming on very nicely! Looking forward to the paint!
ATB.
Thanks Andrew.....hope to get some on it later today. Glad you stopped by. :thumb2:
Thanks Guys, just finished cleaning the A/B.....all went according to plan. I love working with Enamel paint, properly thinned it covers fantastic and smooths right out. Never a tip clog or any spitting. :smiling:
It’s cleaning the remainder out of the airbrush that I dislike about spraying enamels.
Hi Jakko, I use Lacquer thinner to spray through, then block the tip with cloth to create back wash thru the body back into the siphon bottle numerous times, reversing direction of flow and changing out for clean thinner, till it runs clear. Takes about 5-10 min. Probably been a t least 6 mos. since I last took the A/B to pieces for a scrubbing. ;)
Thanks Scottie.....soon as it's dry I'll get a post up with it sat in its wheels....I like to give it at least 24 hrs. Just to be sure I don't finger print myself on it ;)
till it runs clear.
Yeah, that part never works well for me — I spray cleaner through the airbrush, rinse out the cup etc., repeat both until the stuff that comes out is clear, and next time it’s still a 50/50 chance whether it will spray properly. And that’s with acrylics.
I get that Jakko, acrylics, if I'm not mistaken, are based on synthetic products that don't break down the same way enamel, or solvent based products do. I'm not sure what auto manufacturers use now , but back in the day it was all lacquer or enamel based paint. I bought this A/B over 40 years ago and have only sprayed enamel paint through it.....seems to work ok ;)
As promised, here are a couple of pics. with the grey on and I couldn't help spinning the wheels on my moto tool and applying the tire color.....easy peasy! that little blob of putty will be dry soon and I'll repaint the top and it's all detail and weathering from here on. Oops, missed a seam line at the tanks rt. rear....will fix that also.P1012627.JPGP1012628.JPG
This is by no means finished but I just wanted to post up the detail painting and weather progress so far.....will not get a chance to later as otherwise occupied. Pete Lowe loaned me one of his helpers to get this crate finished up ;) P1012631.JPGP1012633.JPGP1012632.JPG
Cracking stuff Rick, and now we know your secret of working at this scale :smiling5:
Thanks Folks, I let the cat out 'O the bag by leaving that little yellow "dude" to waltz around while I was taking pics...should have shooed him off to hang with the rest of his pals up on my tool box. Glad you guys are liking the progress so far. Should have this pretty well finished up in another day or so. Then it is on to the dreaded (but Cleanest) resin kit of the Phanomen Granit 25H Ambulance. Gonna be a bit of a challenge with lots of modifications......stay tuned. :thumb2:
Here's a teaser, you can see the rest of the pics. in the completed softskin section. Thanks for helping me push this along, just one step closed to getting the diorama across the finish line.P1012641.JPG
