In searching for models for 3D printing - I find that a lot of tank models are in 1/56, which are also labelled as 28mm scale, It's obviously a popular wargaming scale. but what actually is it? If you look at the definition of 28mm scale - it ranges from 1/60 to 1/64 depending on source - where does the 1/56 come from?
I'm upscaling models to 1/35, which coveniently is 1.6 X 1/56 size. As a stand alone model, it may not cause a problem, but if you add in figures, and other accessories, that may look a little odd at times.
As a passing interest how did this scale come about? Scales can be verry annoying - Why 1/32 and 1/35? why 1/72 & 1/76?
You can resize according to real specs ie actual size divided by 1/35, but you can be tricked by real specs - is the length including gun forward, or not?
I resized the model of the Orient French battleship, to 1/350, or so I thought. It turns out that the length dimension I used, included the bow sprit!, so the model is probably about 1/320! It doesn't really matter, but can be.................ummmmmmm vexing
