A couple of prints from the Monoprice
Goalkeeper CIWS - Dutch equivalent of Phalanx
Australian 3" mortar carrier in 1/35 - locally produced in WWII - then handed to Nationalist China.
Yellow filament - the Sunlu printer didn't like this, I tried it on the Monoprice with the same settings & it worked! Not very good filament, though, it doesn't seem to give a great deal of detail & strings a lot
The next print on the Sunlu is the longest I've done so far - It predicted just under 20 hrs, but it took 10 minutes under 24!!
It took 84m of filament ( meaning cost was < £4 ). I was getting nervous around the 22 hour mark, as I thought I may not have enough filament on the spool. You can pause the print & change filament, but it's not something I like doing!. I think I've got about 5m left on the spool.
Like a housebrick made of Lego! A lot of supports - all to be carefully removed!
Several hours later..................
British Mk.I Terrapin 4t amphibious lorry in 1/35, upscaled from 1/56. Not very successful, used on operations in the Scheldt Estuary in 1944. It had two engines each driving one side ( it was a skid steerer ) - if one engine stalled, then it could only circle. It was very tall, which made disembarking difficult, if not dangerous, and on land, the drivers' central position gave poor visibilty. The load area was divided in two, making carriege of large sized loads difficult - the US DUKW was far more flexible in its use.
Two white wheels? A case of brainfade - I only printed 6 wheels at first, only realising my mistake after changing filament in the Monoprice..................
Looks like the grandaddy of the Stalwart!
