Oh dear it's a 1/72 Bristol Beveldere
Thanks for the correct names for those items Doug. I only know how to build and bad at describing parts of flying things...it's worse when it comes to the floaty things. I don't even have plans to work with and just eye balling photo references. Now at least I can describe the cockpit parts properly as I post.
Ha ha me too then later on seeing some movies notice the handle can be twisted and elevated up and down while flying and didn't see it abruptly stop. :tears-of-joy:
Wabble
The 'collective' lever also has the aircrafts throttle attached to it. (Oh, I should also add, most collectives also have the rescue hoist wire cutter control as well - which makes most winch men twitch. Stay away from black and yellow switches) PLEASE!! :thumb2:
In essence, to take off, the pilot has to slowly pull the collective lever up whilst applying power by twisting the throttle. Lifting the lever, alters the pitch on ALL the rotor blades, (hence the term 'collective'), giving lift to all the rotors. At the same time, specific to single rotored craft with a tail rotor. The pilot simultaneously applies pressure to the rudder pedal so as to keep the helicopter pointing the same direction to counter the loss of torque when the collective was applied!!!! (In simple terms, stamp feet, rub stomach and pat your head!)
To get forward flight, the pilot then applies a forward input on the cyclic and the helicopter will start moving in a forwards direction. At the same time altering the collective and rudders to maintain a smooth transition from a hover to forward flight. (The reality isn't as straight forward but tbh, Explaining it would get lost in-between my brain and my fingers on the keyboard)
There is a device on the rotors called a swash plate. This converts the pilots inputs on the cockpit controls to movement on the rotor head. (One part being stationary and the other rotating).
Obviously, the tandem rotor craft you are building would apply a few differences due to the addition of the second rotor. One would be rotating clockwise, the corresponding rotor would be anti-clockwise to counter the torque reaction!!
Phew, time for a brew and admire more of the builds on here!!!
Thanks again Doug for the explanation now "I believe I can fly...spread my wings and fly away..." :smiling6: Very helpful.
I do need more help, I have managed to alter one of the rotor heads by inverting and re-doing the bibs and bobs to get a counter rotating prop. Would you know which goes clockwise...the front or back. Here's the modification next to the other original...still needs more detailing...
Airfix made the error to make them turn the same direction I think to save on tooling.
Wabble
It's okay Doug, I just referenced some pictures and they show the front propellers positioned to turn counter clockwise.
Wabble
Wabble
I'll have a scour of the net and see if I can see which way they rotate from images. The Belvedere wasn't in service when I was in nor was it a RN chopper.
OK just read your previous post!! Glad you have it sorted. Just ask if you need anything! Can't guarantee I'll know but after 25 years fixing or flying in them something may be of use!!
Wabble
Does the Chinook props behave the same?
Wabble
Wabble
Yup, both rotors go in opposite directions. It's all to do with torque.
The Soviets get around it by placing one rotor on top of the other both counter rotating. (KA50 - Wiki - KA50 )
Another was the US Kaman HH43 Huskie (Wiki - Huskie )
Friend of mine was an empire test pilot based at Farnborough. He loved the Chinook. Loved telling tales about just how versatile it was.
He would wax lyrical about its turning around either the front rotor. (axis1), or the rear rotor, (axis 2) or centrally, between both rotors. (axis 3).
I had a dislike for them after a visit to RNAD Perth in Scotland where several remains were in a hangar after having had meshing problems with the rotors.
Hi, decided to take my eyes away from the rotor heads for a while and work on the belly bumps. I guess they were different on the prototype that Airfix has with it all the way from the front undercarriage to the back. The later version as shown in references start just before the first window stops halfway of the fuselage with a gap for the stowage hook or searchlight I think and continues till just after the second window. The bump on the Airfix kit was so iffy that I thought it was a mold defect and sanded it down. Here's the replacement with half rod tubes as a guide and part of it that I have puttied and sanded...
I have also inserted a length of plastic tube to guide the rotor shafts so they don't wobble all over the place.
That's it for now.
Wabble
That just shows the standard of this kit. You're getting there Richard.
Thanks Jim, when I wanted a challenge I wasn't expecting it to be this hard. I guess if I had done the prototype as per the kit it would have been half bad. Like shooting myself in the foot with every glance at the kit I see something that needs rectifying or modifying. Even the the aerial needs modification which sits on a box like structure...headache...but enjoying the torture and getting an education on heli stuff from Doug.
Wabble
Hi guys, todays work in progress...rudder pedals and instrument panel.
The parts for the pedals...the large block are the four slices sandwiched with PVA which I'll sand to form the foot pedals.
After the sanding I've got four pedals.
20230902_181630.jpgfront and back of the assembled pedals.
IP in progress with bezels marked out for drilling.
Bezels drilled out and dry fitted to mark the dials to be painted in separate colors before sandwiching the panels together. Work will continue tonight after dinner.
Wabble
Wabble
Superb as always……
Superb as always……
Thanks Tim, I've gone a little overboard on this I think. Meant to be a simple conversion. I could have left the cockpit well alone but having the door slide open meant that a bit of detail had to be added. Airfix doesn't give a cyclic, only a stub, no collective, not even a dashboard/IP. I just hope the rudder pedals can be seen from the large chin window.
Working on the cyclics and collectives next.
Wabble
Wabble
I see your terminology is coming along as well as the helicopter. ;) :smiling2: :thumb2:
In no time Doug, with your help I'll be able to name every nut and bolts.
That's an understatement Richard. Superb work as always.
Thank you Jim.
Richard,
Superb scratchery mate.
You too Scottie.
Today, thickening and extending the prop shafts and a length of wire inserted into pre-drilled holes for added strength so they fit snuggly into the tube.
You've gotta guess where these are going to...
Wabble
Okay, after I smashed the ends of those L shaped thingies with a hammer I attached it to the rotor shaft heads both forward and aft assemblies...
Wabble
Hi guys, I sanded the top and scribed the reverse side of the prop. Unfortunately the release pin marks are on this side and will need filling in.
And just look at the wheels supplied two of which have gaping holes from bad molding process...flash everywhere.
I will either fill with a cut plastic disk or two part putty whichever is the easiest. The holes for the axles are humongous. It's still a good kit...the only kit. :smiling6:
Wabble
Well Richard that's a massive improvement on those rotor mounts. Filling a few pin marks is acceptable but those wheels are horrible. A lot of work ahead of you.
Hi guys, I sanded the top and scribed the reverse side of the prop. (Rotors).Unfortunately the release pin marks are on this side and will need filling in.
Wabble
Nice work on them thar rotor heads. And a nice job scribing the ROTORS, (aka props)!! :rolling: ;) :smiling2: :smiling2: :smiling2:
(We'll make an air fitter of you yet Richard)
