Not sure you want to put acetone on your clear plastic. Try it on a bit of sprue or a spare window if you have one.
Not sure if debonder would be a better bet.
Thanks palMick,
Looking good hope you get rid of the CA.
Several other things out there as well but including WD40 apparentlyAcetone!!! Another school day :thumb2:
I learn more every day I spend on here.
I have done a test first and you’re probably right about the debonderNot sure you want to put acetone on your clear plastic. Try it on a bit of sprue or a spare window if you have one.
Many thanks Andy that’s very kind of you but I actually have some debonder on order, you need to give it a tryMick, I have some VMS Glue-Remove, styrene friendly ca debonder / remover.
I haven't tried it myself but you're welcome to borrow it if it helps.
Do I detect a smidgeon of ironi there Mick...Anyway it’s done and fitted, really can’t wait to build another one
Just a littleDo I detect a smidgeon of ironi there Mick...
But in some strange way interesting. I got a parcel on the way from kit form services. Got the vat bill from customs today so not long now.Just a little
It’s certainly a live one JimThis is certainly fighting you all the way Mick. I'm sure you'll sort the wayward CA blob along with all the other issues.
Despite everything it's looking good and I have no doubt you'll get there.
I’ve got a right hand drive set for a Scania so can’t waste it. Intrigued by what you’ve orderedBut in some strange way interesting. I got a parcel on the way from kit form services. Got the vat bill from customs today so not long now.
Would that be using Tamiya polishing pastes or similar?I reverted to aircraft cockpit polishing for the CA blob on the glass (way too impatient to wait for glue remover) and it worked a treat,
Its just a few bits to build a conversion. Turning an R540 4x2 into a T570... 6x4 lolI’ve got a right hand drive set for a Scania so can’t waste it. Intrigued by what you’ve ordered
Different grades of sanding pads and finished with a Tamiya polish. Quite daunting when you start as it looks dreadful but it does work as I found doing 2 F-16 canopies.Would that be using Tamiya polishing pastes or similar?
Glad that's done :thumb2:
Oh right just a little job, those T cabs do look smartIts just a few bits to build a conversion. Turning an R540 4x2 into a T570... 6x4 lol
Thanks for that Mick. Just lots of patience to save the day.Quite daunting when you start as it looks dreadful but it does work as I found doing 2 F-16 canopies.
Take a peek in latest acquisitions....Oh right just a little job, those T cabs do look smart
Thanks Andy Hopefully tomorrow before I go back on nightsLooking great Mick, I'll eagerly await the finished shots.
