HO 80s/90s CSX, NS, & Conrail layout resurrection.
Thanks Guys. First coat road work.
Tried "concrete" paint......very disappointing. Looks like mud to me.
:thinking: Same here....wonder if you could mix a little grit (very fine sand) in with it and try tinting it to a more grayish appearance?
Rick I thought the colour looked ok, suppose it depends on the original sand colour and the age being bleached by the sun.
I don't mix paint successfully as I'm somewhat color blind. I have to consult SWMBO for anything outside the Crayola Eight. You'll remember The M.O.W. yard had three different colored concrete areas as I struggled to find a suitable color to my eye. The parking lot/supply area had the best, but I couldn't duplicate it as I'd forgotten how I arrived at it years ago.
I looked back & found I'd used Polly S "Old Concrete". Alas, no longer available.
Fourth layer for road, looks like ready for paint. Tried to help out concrete look w/some weathering.
The label was missing, but I think this is the grey they paint aircraft bottoms with. What do you guys think? Did it help or hurt?
C&Cs encouraged.
The work continues. Paving complete.
Prep for gardening.
Found some modern guardrails to install.
Concrete Paul looks ok, remember it all hinges on the amount used in the mix, length of time it's been exposed to the sun .
Coming on a treat is this Paul. Always something new to catch up on.
Thanks gents. Working on a solution to allow gardening behind roadway.
Thinking about foam between road & wall for trees & gardening plus big massif of rock as excuse to veer around w/track. Foam pcs. dedicated for use are in various states of readiness. Siding didn't leave enough room for anything else, so I did away w/it.
Three hoppers have coal, red clay & tan clay for respective bunkers. Banding & banding tools are in central shack & ready bricks are not banded till ready to load.
Looks a lot cleaner and now there is a definite yard lead.......less confusing, to me anyway. Rocks and scenery should make it "POP"! ;)
Hi Paul, it looks okay to me. Concrete generally doesn't dry in a single color so variations in tones ought to look right close to marbling.
Haven't seen this for a while...it's a massive diorama.
Wabble
This just gets better and better Paul. A great deal of work but the details your putting in make it so worthwhile.
Big pictures.
Ballast & dirt applied.
Gardening & rocks next.
Fourth extension under construction. This will be the other terminus of the point-to-point layout.
Wow Paul, there sure is a lot of work in railroads, but it is looking great.
Some progress made on trailer-on-flats yard. Modifications will also be made at the container yard as trailer-on-flats will no longer be accepted there.
C&Cs encouraged.
C&Cs encouraged.
HI PaulE why wont the trailers on flats be accepted there ?
chrisb
